02-02-2016, 06:19 AM | #1 |
My X5d tows my spec miata to the track.
74
Rep 1,254
BMWhat
Hey All,
I bought a BMWhat OBDII communicator and the app for my iphone and have used it to code my 2010 X5D. I have removed the iDrive disclaimer, changed the drls, halos, and windows to my liking and have the digital speedo. The thing also resets my service intervals more reliably than I can using the car's reset feature upon startup - for whatever reason, I can never get that to work. The BMWhat works every time and is very useful to me. I signed up for a beta tester program and for that I'm supposed to recruit more people to use/buy the system. If you're considering one of these things, I recommend it. It doesn't have all of the versatility of the ebay dongle, coding thing but it does a lot and there's less chance of messing things up. I'd be happy to use mine to code your car if you want to see it for yourself - no charge. I'm in Alexandria, VA. If you do want to buy one, my code will save you a couple of bucks. LRD4E4 This code can be entered on www.ivini-tech.de/en directly in the shopping cart, when somebody makes an order for adapters, 5€ will be deducted from the shopping cart value right away. |
02-02-2016, 09:16 AM | #2 |
Rep 266
Had SIB 13 06 15 done to my 12 X5 35d to fix the emissions readiness monitors from never setting / taking way to long to set. And I can no longer code my FRM module. No more 5 flash turn signals or fog lights with high beams.... Till Carly for BMW updates the app, everything else still codes fine.
http://www.bimmerfest.com/forums/att...5&d=1449798061 |
02-03-2016, 06:40 PM | #5 | |
Rep 3,035
Drives: 2022 BMW X5
They recommend Amazon but they don't carry that BMW unit just yet, they say it should be available some time next week...
02-04-2016, 06:38 PM | #6 |
Rep 1,544
Drives: '22 Tesla MY + '23 Tesla MY
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
02-07-2016, 01:24 PM | #9 | |
Rep 313
Drives: 2006 325xi
02-07-2016, 03:51 PM | #11 | |
Rep 3,035
Drives: 2022 BMW X5
02-07-2016, 04:09 PM | #12 |
FDNY Engine 55
681
Rep 2,115
I'm not sure but it's not working for some reason, I can't seem to get it to connect...might be for android
my V-Link worked on every option and was able to code lots of things but won't allow me to code bottom 4 functions...frm, cic, etc. I may have to try and order another 1 or just bring it to my friend to get coded |
02-07-2016, 10:05 PM | #13 | ||
Rep 380
02-07-2016, 11:12 PM | #14 |
Rep 828
For iPhone, it's an additional $15 for the iDrive coding in Carly apps. After that, it's easy to remove the disclaimer within the iDrive menu, as well as enable DVD functionality.
02-07-2016, 11:35 PM | #15 | |
Rep 380
02-08-2016, 12:08 AM | #16 |
Rep 266
02-08-2016, 07:55 AM | #17 |
Rep 828
02-08-2016, 02:27 PM | #18 | |||
Rep 313
Drives: 2006 325xi
Unfortunately looks like it's currently unavailable from Amazon - if anyone is local (Omaha), I'm willing to share Original Carly for BMW Wifi Adapter Generation 2 Iphone and Ipad - Best App for BMW https://www.amazon.com/dp/B00X3UYXM0..._bRpUwbC7RGVMJ |
02-11-2016, 06:32 PM | #19 | |
Rep 3,035
Drives: 2022 BMW X5
02-11-2016, 09:55 PM | #21 |
Rep 38
I ordered 3 days ago and got mine today.. my issue is the same with this bluetooth obd connector as it was with every other cable and connector I have... it connects and verifies that I'm hooked up but then when I click on code or diagnostics it tells me to connect to the car (which I just was) but now it says not connected, so I go back to home and reconnect, then the same thing.. over and over.. I'm using Android V 4.4.x and the new generation II obd connector.. what's the dealio?
