      01-28-2016, 09:51 PM   #1
Juan35i
SSG
Juan35i's Avatar
Drives: 2009 135i
2021 BMW M2 Como  [10.00]
X5 4.8i Bank 1&2 too lean
I'm getting this codes bank 1&2 running too lean any ideas? It also run rough and the rpms going up and down on idle.
      01-29-2016, 02:19 PM   #2
Lucky John
Out to Lunch
Lucky John's Avatar
Drives: 1965 Land Rover Series 2A
I am new to the X5 world so take my thoughts with a grain of salt. Sounds like you don't have good gas flow. The things I would check go like this, fuel filter (I don't even know if they have one), injectors, fuel pump, clogged fuel lines or lines that are collapsing/expanding. Then you get into fuel mapping and coding.
How many miles, has it sat for a long time? Did you put some off brand of gas in it? If you're driving don't let it ping especially going up hills-this is bad for the engine.
      01-29-2016, 08:51 PM   #3
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
I'd also check for vacuum leaks and failing O2 sensors.
      02-02-2016, 12:31 AM   #4
Juan35i
SSG
Juan35i's Avatar
Drives: 2009 135i
It has 117k miles but it started doing it when I had someone replace timing cover gaskets. I checked today and found this broke tho. Would that cause codes or engine to run rough. I always use good gas and keep maintenance up to date.
      02-02-2016, 12:33 AM   #5
Juan35i
SSG
Juan35i's Avatar
Drives: 2009 135i
Here is another picture this is the air line that goes into the valve cover.
      02-04-2016, 02:38 PM   #6
xpl0sive
Drives: bmw
yes those are vent lines that are part of the PCV system. Your car should run very rough if they are broken open like that. They all crack/break at some point as they are made of cheap brittle plastic. They aren't fun to replace and aren't cheap.
Hard to tell exactly which ones are broken, here is a link for the crankcase vent pipe
http://www.realoem.com/bmw/enUS/show...diagId=11_3830
another breather line
http://www.realoem.com/bmw/enUS/show...diagId=13_1034
      02-05-2016, 12:48 AM   #7
Juan35i
SSG
Juan35i's Avatar
Drives: 2009 135i
Yup, the first link is the broken one!!!
      05-07-2022, 01:47 PM   #8
SamBimmerMan
Drives: BMW X5 2009 30I
I have a similar car and I also broke the pcv hose while adjusting the timing chain, by car started idling roughly sometimes as well, mostly when I start it or at stoplights at low rpm’s, it stalled out once on me, I fixed the hose with electrical tape but not sure if that is holding it together, the x5 2007-2010 model has a recall for the pcv heater, maybe that’s something bmw could fix?
