10-17-2017, 03:50 PM | #1 |
Rep 104
Headlamp lens replacement
I see there are headlamp covers for sale. This would be nice vs replacement of the whole assembly. Anyone done this?
http://www.ebay.com/itm/For-BMW-X5-E...wAAOSwopRYdZ~Y |
10-17-2017, 04:08 PM | #2 |
Rep 1,727
I assume you'd need to bake the headlights to remove the lens. Not always as simple as you'd think.
What's the condition of your headlights? Thought of doing a correction on them?
2017 C63 2012 X5M SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i |
10-23-2017, 12:42 PM | #4 |
Rep 17
I've done this. I have a Pre-LCI and did some enhancements to my headlights as well. The lenses have to be cut off however.
https://xoutpost.com/bmw-sav-forums/...ht-lenses.html |
04-25-2023, 08:32 PM | #7 |
Rep 531
Drives: 2007 E70 4.8i, 2008 E90 335i
My e70 X5 $50 shipped ebay headlight lens replacement...
This is a really old thread but I just got around to doing it on my e70 and thought I would share my experience...
I cut off the original AZ sun faded headlight lenses from my e70 and replaced them with $50 shipped Gplus versions from an ebay seller. Getting e70 headlights out is a real PITA. It requires pulling the inner fenders, and fighting to get them past a support bracket. Then cutting the old lenses off and getting them prepped also took quite a bit of time. Cutting the lenses off requires a lot of patience, it is easy to cut into the inner gray trim or even the angel eye if not careful (I nicked an angel eye but it wasn't bad enough to matter)... This was a ton of work. The original BMW sealant is more like silicone than butyl... I was able to get the new butyl done with just a heat gun rather than an oven. I didn't see the need for putting the whole thing in the oven when some careful work with a heat gun to heat up the edges worked just fine. Here is one side, the spec in the lower right isn't a defect, it is a reflection or spec of something on the outside. The new lenses (and my other cars) are getting lamin-x film ASAP. Never let them get this bad... I probably could have sanded them out but I thought that the $50 housings were a great price and would give a better result. They probably did but it was also more work than sanding them... I did have one major setback that required rework during the process that I wanted to warn about... I got tired at 2am and when I assembled the driver side and got it all done and realized that the outer edge of the inner gray trim wasn't aligned (the tabs weren't engaged so it looked really bad). This meant I had to pull it all out again, re-heat the new butyl, clean it up and add new butyl but at least that is possible with the butyl unlike the factory sealant. -Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. |
