      09-28-2014, 10:16 PM   #1
altawila
Drives: BMW x5 48i M sport
Forgestar CF10
Hello, looking for some help fitting a wheel to my 2010 BMW X5 m sport.
I have purchased a set of forgestar cf10 used. Looking to fit to my x5. Will I need hub rings? Can I run a square tire setup? If so, what size? Here are the wheel specs. Thank you in advance.
Color in Gunmetal, bolt pattern 5x120 and 74.1 centric bore for BMW fitment.
Front:
Offset: about 20mm, backspacing measured 5 11/16.
Rear
Size 20x11
Offset: about 40mm, backspacing measured 7 9/16.
      09-29-2014, 05:29 PM   #2
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
you won't need hub rings for an M Sport (50i or 35i I assume?)
you won't want to run a square tire setup though.
