      08-27-2013, 11:39 AM   #1
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
Low res to high res backup camera retrofit
I have an older version (low res) backup camera in my 09 X6 and I want to change it to the newer, high resolution version. Has anyone done this retrofit end-to-end? What is all that's required (other than obtaining high-res backup camera) hardware wise and then what coding is required? Will i have to replace a controlling module as well?
      08-28-2013, 09:23 PM   #2
MaX6
Drives: 2011 BMW X6 50i
I would suggest you contact the guys at BimmerTech.. http://www.bimmer-tech.net/
They did some coding to my car recently and are excellent..
      08-28-2013, 11:06 PM   #3
igorbmwx6
igorbmwx6's Avatar
That is true. Patryk and MEN are great and very knowledgeable guys. I would definitely contact them for this; however, I am looking to do this myself to save some $$$. Just wanted to know if someone out there attempted to do this particular retrofit themselves. Thanks for the advice anyways
      08-29-2013, 07:24 AM   #4
MaX6
To go the DIY route I believe you are going to need to add a new video module to the factory harness to accept a new video source... I did this to my X5 and worked great.
You will need to add a NavTool or similar plus the new carmera...
http://www.navtool.com/bmw_X6_2008-2009.aspx
For the camera I used a high quality Boyo.... Very happy with the results..
good luck.
      08-29-2013, 11:18 AM   #5
igorbmwx6
igorbmwx6's Avatar
good luck.
Looks like an after-market control module. I prefer to stay with BMW oem (original). Can I swap out my current module with module that normally goes into vehicles equipped with high-res backup cameras? replace the camera itself and re-code?
      08-29-2013, 12:23 PM   #6
MaX6
I may be mistaken but I believe the issue is the incompatibility of your 2009 CCC with the 2010+ camera's.. Anything can be done if you through enough money at it but I believe you would need to swap out your CCC for the 2010 + CIC and that is an expensive endeavour...
      08-29-2013, 12:54 PM   #7
igorbmwx6
igorbmwx6's Avatar
That's already done, I have CIC + Combox already What else do I need for high-res backup camera ?
      08-29-2013, 01:58 PM   #8
MaX6
sounds like you are half way home.. I would guess new camera and coding but I'll have to defer to the experts on here to hopefully help you out..
      08-29-2013, 02:59 PM   #9
igorbmwx6
igorbmwx6's Avatar
Thanks for your feedback; however, I am still unsure whether I will need just a high-res backup camera to replace mine or also new control module for it
Tags
backup camera, coding, e71, retrofit
