      08-04-2013, 07:00 PM   #1
the doc
M A R S O
Drives: F30 335d LCI F87 M2 LCI
So I want to self install CIC sat nav - where do I start?
Hi all,
Can any coding gurus help?
I have a late 2009 E70 X5 with the CCC nav system and wish to upgrade to the CIC system and I'm hoping that somebody on here may have also done this.
Does anybody have any fitting / wiring guides?
Can anybody here help with coding?
Thank you in advance.
Regards
Craig
      08-15-2013, 03:52 PM   #2
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
Originally Posted by the doc View Post
Hi all,
Regards
Craig
Craig, for starters you will need to obtain: CIC, new iDrive controller, new high-resolution screen, two new trim pieces, one new frame for the new iDrive controller, activator p-n-p cable with adapter, usb ports, one for glove box, one for arm-rest, usb cables one for glove box, one for arm-rest, adapter for new high-res monitor, Combox to replace TCU, p-n-p cable for Combox. Once you have all of the required hardware in place, then comes the programming part. That is fairly simple and straight forward. Oh yeah, almost forgot, you will need latest NAV MAPs (3DVD's set) and will need to purchase installation key for the MAPs. I will help you out with getting it all coded correctly.
      08-15-2013, 04:24 PM   #3
isugoo
isugoo's Avatar
Drives: 991.2 GTS
Hi all,
Regards
Craig
Search in M3Post side. Quite a few members did it with nice DIY write ups.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3
