      07-22-2011, 04:23 PM   #1
burcham2
Drives: 2016 F85 X5M
NAV HACK -Anyone daring to attepmt?
Is anyone our there trying to mod the nav to you can watch video while in motion?
it appears if you put a switch on some sort of 'parking sensor' along with the motion sensor, then it could trick the car into thinking its parked, which would allow video playback. ...anyone try this yet, or know of another forum where the wire locations can be found?
2016 F85 X5M black/red dinantronics stage 1, execuhitch, coding
2017 911 991.2 Carrera S white/black
      07-22-2011, 04:33 PM   #2
mattpdx
Drives: 2018 440i
You can also get this through coding. I had mine done by Patyrk. He uses remote desktop and a cable to configure the car. He is in poland I belive. No modifications of parking sensors needed.
      07-24-2011, 04:15 PM   #3
sunnygps
Drives: 2012 X5d
On the CIC based navigation, it can be done via coding. Very easy to do.
      07-25-2011, 01:17 PM   #4
burcham2
whats the best way to change the coding with the CIC nav? I usually mess with the wiring, but coding would be simple; what program is commonly used and how does one one connect to the nav to edit the coding?
