      07-19-2014, 08:53 AM   #1
bmwstve
Drives: BMW X6, MHD Stage 2
E85 fuel = Increased horsepower?
Can I safely run E85 fuel on stock 2011 X6?
Will it increase horsepower/torque?
How about fuel consumption?
Thanks
      07-19-2014, 01:13 PM   #2
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
Inside the fuel door it says what type of fuel to use, you didn't state if it was 35i or 50i but I don't think E85 is an option.
2022 X6MC - 2011 335D
      07-20-2014, 08:07 AM   #3
bmwstve
I'll check it, its a 35i by the way
anything i can do to make it drive faster?
I'm also looking into purchasing tuning kits like JB performance, however I've read on another post that it causes damage to the ecu..
      07-20-2014, 08:48 AM   #4
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
Nope. Can't use E85 on a stock X5.
There may be a conversion kit around, but BMW's official stance is they don't recommend it.
Contrary to some info floating around, 'good' E85 tops out at about 94-97 octane and not 105 octane. Also, this octane rating will decrease substantially within a relatively short time as the fuel ages, so if you buy from a station with old E85 (no way to tell) you'll get a lower octane than you'd get with normal premium.
To top it all off, E85 gets about 30% less mpg than regular fuel, so unless you're local price is >30% less expensive than premium it's not even a good value.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      07-20-2014, 03:38 PM   #5
dmlgc
dmlgc's Avatar
If you are going to do tuning then I recommend Dinan, they know more about tuning BMW's than anyone. some dealers will install Dinan software for you. Also they do exhaust stuff.
take a look http://dinancars.com/:
X6 35i Stage 1 performance boost about $1000
60 More HP; 74 More lb-ft of Torque
      07-21-2014, 11:42 AM   #6
bmwstve
Thanks, I'll check on it!
      07-21-2014, 12:47 PM   #7
Draper
Draper's Avatar
3461
Also check out.
http://www.burgertuning.com
They have some amazing options, which are surprisingly cost effective...plus a huge community following.
http://www.n54tech.com/forums/
      07-21-2014, 10:25 PM   #8
bmwstve
Originally Posted by jzbm3 View Post
Also check out.
Thanks for the help!
My X6 is a 2011 35i so for Burger tuning I only found this:
http://burgertuning.com/N55_Jb_BMW_P...nce_Tuner.html
But..
I researched more about the Burger JB tune, I was able to find this post
http://www.xbimmers.com/forums/showt...php?p=16302574
He said that the ecu on his 2013 X6 35i was damaged after using the JB tune.
Is the tune for 2011 X6 different from 2013 X6?
I'm quite unsure of purchasing JB tune after reading the post though.
Does anyone have experience with JB tune N55 Stage 1 for 2011 BMW X6 35i?
      07-22-2014, 02:43 PM   #9
Draper
Draper's Avatar
3461
But..
Hmm, interesting.
Realistically though, it's not possible to tell what caused the issue so it could have been a case of the JB4 being improperly installed, and/or just a coincidence that the computer failed while the tune was installed. I've seen a few other cases where someone doesn't connect a harness all the way, and they get reduced power messages...easily cured by ensuring everything is plugged in securely.
Also, the JB4 has some adjustable settings, so it's possible those could have been messed with as well.
The Stage 1 is a pretty mild tune in comparison.
The N54tech forums will be your best bet for feedback from those who have the tune installed.
      07-23-2014, 07:51 AM   #10
bmwstve
Hmm, interesting.
Thanks, I better do some more research regarding this
