11-06-2016, 05:42 PM | #1 |
Rep 265
BMW iPhone 7 connectivity via USB/Ycable?
Hi everyone,
Proud new owner of a 2011 X5. Car came with a y cable for the iPhone (older gen). Went and bought the 30 pin to lightning adapter and the car reads my music perfectly. However, no sound! Assuming because the cable with the car has a headphone jack as well. If this were a iPhone 6 or prior I assume I'd plug that in as well and we'd have music. Does anyone know the work around or whether another adapter is available to make this work? Thanks |
11-06-2016, 10:53 PM | #5 |
Rep 265
11-06-2016, 10:58 PM | #6 | |
Rep 265
As mentioned before, the Y-cable with adapter reads perfectly and reacts to my controls, just no sound. I assume because the sound is dispersed via the headphone jack of the y cable? Now that the iPhone 7 has lightning only, I need an alternative. |
11-06-2016, 11:12 PM | #7 | |
Rep 9,134
Doesn't Apple offer Y cable with the 7 to allow the 3.5 audio jack?
IF so you need that. Quote:
11-06-2016, 11:20 PM | #8 |
587
Rep 898
The BMW Y cable will interface and passthrough audio via the 30 pin, the Lightening to 30 pin should also support audio passthrough unless apple nerfed it recently.
Have you tested to make sure your Aux port is good, and the Y cable isn't defective? |
11-06-2016, 11:26 PM | #9 |
Rep 894
There's a bmw lighting y cable, just get that.
http://www.ebay.com/itm/like/3223161...&ul_noapp=true My guess is the apple 30pin to lightning adapter is for data only, not audio.
11-06-2016, 11:26 PM | #10 | |
Rep 265
Y-Cable works on its own. |
11-07-2016, 02:21 AM | #11 |
Rep 99
A I had the same Y-cable setup with the 128 I just sold (before getting my 7 Plus). There are going to be a lot of adapters involved if you can get it to work. Maybe one of these Belkin lightning splitters plugged into the phone. Into one of its lightning connectors, plug in the Apple-provided 3.5mm headphone adapter. Into the other one, plug in a lightning extension cable. Now you’re in the same situation as with a pre-7 iPhone. Good luck!
2017 M240i Cabriolet RWD 6MT. Glacier silver/coral red, alu hex/blk trim, moonlight blk top.
11-07-2016, 12:32 PM | #12 |
Rep 266
My iPhone 7 works just fine with the lightning to USB cable. I have a 2012 x5.
Is your idrive up to date? http://www.bmw.com/com/en/owners/con...re_update.html |
11-07-2016, 05:21 PM | #13 |
Rep 1,579
Iphone lightning will work with a combox which OP does not have. When apple switched to lightning they changed the audio to digital so you need a d to a converter. Y adapters don't have this but Combox does. Tune2air is probably the best option. https://www.amazon.com/ViseeO-WMA300...words=tune2air
I used the tune2air for the past year and it works great. I switched to combox because I got one cheap and the only real difference is I can connect and switch between multiple BT devices. |
11-08-2016, 12:55 PM | #14 | |
Rep 47
11-08-2016, 01:27 PM | #15 |
Shoot for the moon
Rep 105
It can work but you need the right combination of options. See my response in CDNBimmer's other thread on this topic...
11-09-2016, 10:29 AM | #16 | |
Rep 265
Tested a different y-cable and I have audio Thanks for all the feedback |
11-09-2016, 08:49 PM | #17 |
Shoot for the moon
Rep 105
