F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N55 f30 open downpipe concern
Extreme Powerhouse
      03-15-2024, 05:20 PM   #1
Managable
Drives: 2014 BMW 335i xDrive
So my car’s year is 2014 and I have stage 1 bootmod3, catless downpipe, unplugged maf (misfires a lot and undrivable with in plugged in), and cold air intake. I don’t have access to a dyno but I do have the sport display. When I have my exhaust connected it peaks at 380hp on the sport display but when I run an open downpipe is peaks at 450hp. I’ve been looking up a bunch of information to see whether this will over boost my turbo and cause damages to it etc. I love the sound and power it adds but I wanna know what’s adding that power and how it will affect the longevity compared to a connected exhaust. I’ve done pulls tracking the pre throttle psi and open dp peaks at 18psi full throttle and connected exhausts peaks at 17.5psi (it was only one pull). Yes I know it burns the bottom of the car I’m looking at turning it into an open dump if it’s okay to run.
      03-15-2024, 09:05 PM   #2
Slumped335
Drives: BMW 335i
  [0.00]
What intake are you running that would make your MAF useless? Could it be a bad MAF?
While I'm sure the less restrictive exhaust would technically make more power, I doubt its a 70hp difference. At that point you might as well just get a straight pipe kit and call it a day. Better than whatever may happen with a open dump under the car.
As for the boost.... Back pressure is good for low end torque (could be wrong but I've heard that's the general consensus), But is the 0.5 psi of boost worth having a open dump? I feel like the means are not worth the gains.
What is your goal in this? More Power? Sound?
      03-16-2024, 05:40 AM   #3
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
If you can't drive the car with the maf plugged in you have a ton of issues that need to be addressed asap.
Youre not gaining big power with an open downpipe unfortunately.. btw the guages aren't exactly accurate
Backpressure is bad for engines actually.. however because of how physics work.. exhaust pipe (diameter and length of it etc) creates high and low pressures and a bunch of other stuff that increase the speed of exhaust leaving from the engine and so on.. it's why it's important to have the right exhaust. On turbo engines for high hp having almost no exhaust is better. The size of the engine, turbo and rpm will dictate but generally an open exhaust of no more than a few feet is best.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      03-16-2024, 09:43 AM   #4
LA1Z24
Drives: 2014 435i M Sport
All I have to say is this...
You don't magically just get 70hp because you disconnected the exhaust.
Also, fix your car. You're worried about engine damage but you're knowingly driving it around in a broken state. So yea....fix your shit.
F22Cam61.00
n55david1295.50
Jvac432.00
      03-16-2024, 01:53 PM   #5
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
This.. it's hilarious but this
      03-16-2024, 09:25 PM   #6
Managable
So after I installed my catless downpipe I started getting the misfires. I read a lot of forums and couldn’t find a solution. Unplugging the Maf and putting it in alpha-n mode seemed to be my best bet any ideas on how to fix it cause I wouldn’t mind it working. Also I did buy a new MAF and plug it in for it to yield the exact same misfiring issues.
      03-16-2024, 09:30 PM   #7
Managable
I know 70hp wasn’t probably right, but still a jump in power just worried me that I could blow my turbo. Like I replied to the other guy my misfires happened as soon as I added my downpipe. I did have an exhaust leaked which I later fixed and tried it plugged it (same issue).
      03-18-2024, 12:53 PM   #8
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
If your car ran fine before you installed the DP then you should start there... Mostly likely problem is with the O2 sensors. Did you swap the plugs? Did you damage the O2s when moving them? Where's your datalogs?
f30post
