F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Bay Area Smog?
Studio RSR
      09-05-2023, 12:54 PM   #1
ski0351
Drives: @135i_ski0351
Bay Area Smog?
Any one know of a place to get a catless dp car smogged in the Bay Area?
please dm.
      09-05-2023, 01:17 PM   #2
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
This is pretty much a no-go on a OBD2 car, especially in California. You can't just pay under the table to pass sniffer like a pre-OBD2 car. Swap the OEM DP back on, flash to stock, relock DME, and complete a drivecycle.
      09-07-2023, 10:16 PM   #3
SpoolinAddict
Drives: 2015 F30 335i Stage 2 BM3
Have you gotten your car smogged yet? From what I remember, you had a Fabspeed or something similar that doesn't give CEL. Wondering if that's the route I want to go, since I don't really like catless (smells too bad)
      09-08-2023, 08:45 AM   #4
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
please dm.
Sure thing mr. not_a_cop
Mods: Yes.
      09-08-2023, 11:53 AM   #5
thejeremyman9
4364
Yes, i run fabspeed. No CEL and no issues.
      09-08-2023, 03:36 PM   #6
SpoolinAddict
Does the Fabspeed catted dp look similar to the Stock DP? or is it one of those things where you have to find a smog shop that's sorta lenient on passing the Visual
      09-08-2023, 08:01 PM   #7
thejeremyman9
4364
If you are just looking down in the engine bay from the top, it looks quite similar, since you just see the "bulge" from the cat, the O2 sensor, etc, and the size/shape from the top is basically the same. However if they start looking under the car or using mirrors, it has a fabspeed label. It just depends how hard they look.
I went to a new shop this year and they did specifically look at the DP from the top and didnt say anything. They did call out my turbo inlet (silicone MST v2). Surprisingly didnt say anything about my CP that is heat-wrapped in gold and probably the most visible mod of all. What i have found is that if you are able to pass the OBD2 checks, which are quite extensive now (for both monitors and tunes, etc), then the visual things like an intake, inlet, CP, or IC usually wont be a problem.
If you have a pre-OBD2 car is a entirely different ballgame. When i brought in my 3000gt they used mirrors and whatnot to read the labels on the cat and put it into the CARB database. Not to mention all the functional tests. There are some engraved letters i believe on the BMW DP, but i think they generally just rely on the OBD2 tests to confirm everything is "legit" for the newer cars, instead of inspecting parts in detail. YMMV
      09-08-2023, 08:36 PM   #8
SpoolinAddict
Got it, thanks a lot man. I'm still on the fence with the Fabspeed or just switching every 2 years haha
      03-16-2024, 12:42 PM   #9
F32Hiraaa
Drives: F32 435i
Hey, were you able to find one? I知 also in the bay area, and I知 unsure if my MSL thermostat will affect my smog passing capability, I知 also running an MHD tune aswell.
      03-16-2024, 05:43 PM   #10
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
You have to remove mhd to pass now
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      03-16-2024, 07:00 PM   #11
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
Nazi state.
      03-16-2024, 10:09 PM   #12
F32Hiraaa
Drives: F32 435i
Would i have to remove my MSL thermostat to pass though or no?
      03-18-2024, 12:54 PM   #13
thejeremyman9
4364
You shouldn't have to remove it to pass functional tests, no. But in theory i guess it could fail the visual... doubt that will be an issue though. just go back to stock tune, get all your monitors ready, and go in.
      03-18-2024, 02:28 PM   #14
F32Hiraaa
Drives: F32 435i
Hello, just went to the smog and didnt have to remove my aluminum shiny cp and msl thermostat and passed
f30post
