F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Cylinder 4 misfires! Can't find the problem
Extreme Powerhouse
      05-12-2022, 09:31 PM   #1
Felixrobb
Drives: Bmw F30 335i Xdrive
Hi all,
I have a problem with my cylinder 4 and cant find whats causing it. I have misfires only in that cylinder and I already changed spark plugs, coils, injectors.
The misfires happen only when RPMs are below 3k (at idle and sometimes when i drive under 3k rpm). They happen when the car is warm, and its worst if the temperature outside is hot. Sometimes the car shuts off when im in traffic and i get like 40misfires in cyl 4.
Its been months and no one seem to figure out whats wrong! It's so frustrating. Any one have an idea what could it be?
The only code i get is:
118002 Mixture too rich
      05-12-2022, 11:30 PM   #2
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Did you compression test cyl 4?
      05-13-2022, 08:20 AM   #3
BMWILUVU
Drives: 340ix
Originally Posted by Felixrobb View Post
Hi all,
You might want to look at the intake valve, maybe starting to have carbon buildup. This problem as it gets worse usually causes lower RPM misfires.
      05-13-2022, 08:36 AM   #4
Felixrobb
Hi all,
I had the intake valves cleaned last fall so i doubt this is the issue
      05-13-2022, 08:37 AM   #5
Felixrobb
This was the next thing to do on my list, but the symptoms of a bad compression don't really match what I'm experiencing right?
      05-13-2022, 09:19 AM   #6
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
That was never gonna be the issue unless you had another huge issue with your pcv setup.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      05-13-2022, 09:22 AM   #7
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
I would check it. It can be a symptom yes. It just depends. Not likely but possible.
      05-13-2022, 09:25 AM   #8
Felixrobb
Alright thanks, i'll keep you posted
n55david1295.50
      05-13-2022, 11:48 AM   #9
BMWILUVU
Drives: 340ix
If your compression is too low you will not get combustion. Therefore the rich mixture detection by the O2 sensor. It may be a problem in development and therefore showing up at lower RPMS. The question if you are not holding compression in 4 relative to the others is why. Could be something wrong with cylinder 4, its rings, or even a valve. Where did you get your plugs/coils/injector done?
      05-13-2022, 12:08 PM   #10
thejeremyman9
4364
The tricky thing is, incomplete combustion will actually read as lean, not rich. The O2 sensor measures oxygen, not fuel, so any incomplete combustion (which causes both excess fuel and air in the exhaust) reads as lean. The O2 sensor doesnt care how much fuel is in the exhaust, since it doesnt actually measure the air/fuel ratio or fuel at all - just oxygen
Anyways, compression test cyl 4. If it shows as good (probably test all of them at the same time to get variance), then start swapping coil and plug with 4 and another cylinder. I know they are new, but new doesnt always mean good.
      05-13-2022, 12:09 PM   #11
Felixrobb
Oh i see! Thanks very helpfull
Everything is done at a BMW specialized shop so i'm confident everything has been done the right way, the parts are also all OEM.
      05-13-2022, 01:02 PM   #12
BMWILUVU
Drives: 340ix
Unless you are comfortable doing it yourself, since obviously they had not resolved the issue on 4, I would take it back to the shop and tell them you are getting misfires they supposedly fixed and give them the Rich Mixture code. I'm sure they will know what to do just say they hadn't fixed the problem after spending $XXX and kinda mention a compression test maybe they'll do it for nothing.
      05-16-2022, 05:59 PM   #13
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Wiring?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      05-23-2022, 09:59 AM   #14
Fondry
Drives: 2013 335xi Stage 2
i had the same issue, after chasing it for almost 3 months, an indy shop near me figured out it was the DME had a ground that was shorted out causing the misfire. I replaced my DME and it was back to perfect with no misfire
      05-26-2022, 01:11 PM   #15
Felixrobb
Compression test done, compression is fine in all cylinders. So new spark plugs, new coils, new injevtors, compression is fine, no vaccum leaks..... ugh
      05-26-2022, 01:13 PM   #16
Felixrobb
I'll have a look at the DME. How much did the new DME cost?
      05-26-2022, 05:26 PM   #17
LA1Z24
Drives: 2014 435i M Sport
The valvetronic return spring coming off the intermediate lever will also cause a misfire. There will be a noticeable pop from the exhaust whenever that cylinder fires. Will almost certainly damage the cam lobe in the process. Had it happen to mine. Compression will show normal with this failure. Running compression test will show an abnormality in this cylinder compared to others. https://photos.app.goo.gl/Ms46TUtKVVp9wEuGA
      08-03-2022, 12:13 PM   #18
AlpineweissF10
Drives: 2012 535i Xdrive
Was this ever resolved? My issue is very similar with cylinder 4 misfire and rich condition. New coils, plugs, injector, compression and leak down test all good.
      08-03-2022, 08:19 PM   #19
LA1Z24
Compression needs to be done while cranking, and also a running compression test. All of those CAN NOT test good, while having a misfire.
Remove the valve cover, and inspect the valvetrain.
      08-03-2022, 10:08 PM   #20
AlpineweissF10
I did a static compression test by disconnecting the fuel pump and removing spark plugs and connecting compression tester and cranking for about 10 times for each cylinder. They all came in around ~210 (+/- 2).
I then did a leak down test and it showed less than 4% leakage for each cylinder.
Sounds like you did a running compression and that was the issue. I'll look into that next. Hope that's not the case.
      08-04-2022, 05:36 PM   #21
Felixrobb
Nope, Still not resolved...
      08-04-2022, 06:38 PM   #22
thejeremyman9
4364
Did you check valvetrain as mentioned above?
f30post
