      07-18-2020, 06:54 PM   #1
igell
Drives: 2011 x5m
X5M whistle at acceleration and loss of boost
Recently started getting some whistle at acceleration and sometime it seems like the boost actually dies.. (i hit the gas from a stop and the truck slows down for a sec or two before taking off again)
I assume i have a boost leak as crack in some of the plastic hoses under the hood. where should i start looking?
2011x5m
      07-20-2020, 09:40 AM   #2
Colodano
Drives: 2010 X5M
Sounds like you already know the answer, if there are cracked hoses, replace them...
If you cannot readily identify the leak at that point, take it to someone who can smoke test it.
      07-20-2020, 11:42 AM   #3
igell
Drives: 2011 x5m
is there a simple way to replace these plastic hoses with silicone ones that dont crack as easily? I saw the catchcan wright up but i am not quiet sure i am ready to go that route yet.
      07-20-2020, 08:29 PM   #4
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
Not that I'm aware of, there is no aftermarket solution or custom solution to replace the cracked ccv lines. Except with oem.
      07-21-2020, 03:53 PM   #5
Colodano
Drives: 2010 X5M
There are so many hoses, it really depends. The big hard plastic tube from the turbos to intercoolers, that pretty much has to be stock, but the hoses into and out of it can be replaced with silicone.
The CCV lines either go with new stock, or do a custom catch can setup, if you do some digging on here you will find examples.
There is a good writeup on replacing the fresh air vents and ccv lines that also covers the turbo inlet and outlet stuff well.
      07-21-2020, 04:09 PM   #6
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Could also be the diverter valves not holding the pressure.
      07-21-2020, 05:00 PM   #7
igell
Drives: 2011 x5m
the guy did a smoke test and said that there was smoke coming from the turbo inlet piping right at the turbo. Is there a seal that i can replace or do i need to replace the whole pipe?
It looks like its just clamps there.. so i should be able to just use different clamps... what size does it use?
      07-21-2020, 05:01 PM   #8
ncmoore12
ncmoore12's Avatar
Drives: 2013 BMW X5 M
2013 BMW X5 M  [0.00]
Where did you get this done at and how much did it run you? also in the bay Area. I already replaced my back CCV lines the easier ones.
2013 E70 X5 M - SG
2001 E39 530i - M-Sport, MT,TB
2011 E93 335i - M-Sport, BSM
      07-21-2020, 05:11 PM   #9
igell
Drives: 2011 x5m
I actually have not yet gotten it done.. they guy quoted me 200 for labor which seems high just to replace some clamps. i am going to see if i can do it myself.
It was 100 for diagnostics and smoke test.
      07-21-2020, 05:24 PM   #10
TwinSnailz
TwinSnailz's Avatar
75
Drives: 2011 X5//M
Inlet pipe had the pcv valve connected to it. The pcv on the right side (passenger side) is just a flap that allows air from the crankcase to recirculated back to the turbo intake. A smoke test on this side is invalid as it is intended what it’s design to do.
Just my personal test that i have done on my M because of the whistle noise.
      07-22-2020, 09:41 AM   #11
Colodano
Drives: 2010 X5M
Where the fresh air vents go into the turbos there is a seal that gets hard, I have had to replace mine twice in under 3 years of ownership. But that seal shouldn't cause low boost, just a possible vacuum code.
It does take some time to get in there, so a mechanic charging under 2 hours to do it is entirely reasonable.
That said, I would keep looking for a whistling under boost, I doubt that will be the real issue.
