06-30-2020, 07:16 PM | #1 |
2022 M4 Comp Xdrive
1016
Rep 1,539
Wheel question
I purchased a square setup some months ago. They are 20" wheels that are 10.5" wide.
I wanted to use them for summer on my '13 x5m. I just recently learned that you need to be careful to stay with in 1% variation otherwise the cars system does not like it....and could be harmful to the drive line. If I was to get 305/35/20 tires for the front and back...does that work? If not...what does? |
06-30-2020, 08:47 PM | #2 |
Rep 104
Drives: E39 M5, E70 X5M, 90 Z32TT, 360
That tire size should work or the stock size, 315/35/20.
2000 E39 Dinan M5
2010 E70 X5M 1990 Straman Z32TT 2001 Ferrari 360 Spider 1996 Mitsubishi 3000GT Spyder |
06-30-2020, 11:00 PM | #5 |
2022 M4 Comp Xdrive
1016
Rep 1,539
07-01-2020, 08:06 AM | #6 |
Need mo $$s
833
Rep 885
Sorry, they are stored for the summer.
Been using that setup for 6+ years, no issues at all. They look great!!! Here's the spec info from the EXTREMECONTACT DWS 06 - SIZE: 315/35ZR20 tires: Think your source for information may be a bit questionable. Thanks, John
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
07-02-2020, 12:30 PM | #7 | |
2022 M4 Comp Xdrive
1016
Rep 1,539
I showed my installer this info and I'm going with 315 all around. How is the turning with the wider wheels upfront |
07-02-2020, 12:42 PM | #8 |
Need mo $$s
833
Rep 885
I have the OE size 275/40-20 on the fronts...
Only have the 315s on the back.
07-03-2020, 02:14 AM | #10 |
2022 M4 Comp Xdrive
1016
Rep 1,539
Last question....these new wheels have a 30 offset... (Bare with me...first time I'm using aftermarket wheels...ever...)
I know the stock fronts are 40, rear are 35 offset. If I use these wheels (10.5" width, 20 diameter and 30 offset) coupled with 315/35/20 tires ..is that going to rub anywhere? I'm going to use 20mm spacers for the rear. |
07-03-2020, 07:48 AM | #11 |
Need mo $$s
833
Rep 885
Hi,
Here's a wheel calculator you can use to answer your questions: https://www.1010tires.com/Tools/Wheel-Offset-Calculator Looks like you will be fine on rubbing. Front: Rear: Be sure to check the hub bore also: Post a photo when you get the new setup done. John
07-03-2020, 08:30 AM | #12 | |
2022 M4 Comp Xdrive
1016
Rep 1,539
Thanks Yea the spacer I have in the back converts the 72 bore to 74. The new wheels are all 74 bore. Fronts should be no issue just needed that adaptor feature on the spacer which I was able to find. |
07-03-2020, 10:23 AM | #14 |
Need mo $$s
833
Rep 885
Yep, will push it out where you will like it.
07-05-2020, 06:14 PM | #16 |
2022 M4 Comp Xdrive
1016
Rep 1,539
Hmmm back on this again...about to order the tires but did a search online and I found one post where 285 was to much for the front and didn't clear.
Is that true? Then 315 will definitely not work for the fronts |
07-05-2020, 06:35 PM | #17 |
Rep 93
315 is to big i have 21 10.5 offset 20 and im running 295 35 and on full turn it touches the fender liner.
07-05-2020, 06:41 PM | #18 | |
2022 M4 Comp Xdrive
1016
Rep 1,539
I checked the specs for the Michelin Pilot Sport 4S and the minimum rim width for 275/40/20 is 10.5 so it should fit. I guess I'll be running a stock tire setup on a square wheel set. (315/35/20 on the rear that are also on 10.5" width wheels) |
07-05-2020, 06:43 PM | #19 |
2022 M4 Comp Xdrive
1016
Rep 1,539
@95wildtt this is essentially the same as your winter setup then, correct?
You have 10.5" width wheels for all four but front tires are 275 and rears are 315? |
07-05-2020, 06:59 PM | #20 |
Need mo $$s
833
Rep 885
Hi,
No I have a 9.5" Front (275/40-20) and 10.5 rear (315/35-20) for my winter setup. I do run a 25mm spacer on the fronts to clear my ///M brake setup, so similar offset to what you are going to have. You should be fine with the staggered (275/315) tires as they both fit on the 10.5" wheels and will provide the correct rolling diameters. This will give you the clearance in the fronts and matched revs/mile just as the OE tires.
07-05-2020, 07:51 PM | #21 | |
2022 M4 Comp Xdrive
1016
Rep 1,539
