      03-20-2020, 08:29 PM   #1
ivstealth
Drives: 2015 BMW 335
X5 Key Fob doesn't work after coding
Anyone know why after coding the 2012 BMW X5 that the key fob trunk release button now doesn't work? I coded two of these cars and now they both don't have functioning key fob trunk release buttons. They both can activate the alarm and they both can now shut the trunk with coding. But why can't it now open? When I reversed the coding it still continue to not open. Anyone know why?
Thanks
      04-03-2020, 06:09 PM   #2
ivstealth
Bump
      07-05-2020, 01:19 AM   #3
vangev
Australia
Drives: 2017 X5 xDrive 30D
2017 BMW X5 F15  [0.00]
Thanks
Im in the same situation. Do you find the way to fix this issue?
      07-05-2020, 01:21 AM   #4
ivstealth
Thanks
Unfortunately no solution. Seems like an issue that I can't figure out kt this date, even with manual coding. Do you also have a diesel x5?
      07-05-2020, 01:31 AM   #5
vangev
Australia
Yes. 2009 X5 3.oD xDrive.
I will appreciate if someone help us to we re/code using exert mode.
I coded my 2017 X5 3.0D F15 as well and everything works perfect, but stuck with my E70
      07-05-2020, 01:33 AM   #6
ivstealth
Unfortunately I've coded three x5 diesels that have that same problem. I've done other x5s 4.8 and 3.0 and they were perfectly fine. It must be an issue with the diesel. I've coded it through expert as well. No luck, and even tried to go back to default settings. I couldn't get it working.
      07-05-2020, 01:37 AM   #7
vangev
Australia
ivstealth, what you use for coding?
I'm using "BimmerCode App" with "Veepeak OBDCheck BLE" adapter and iPhone Xs
      07-05-2020, 01:38 AM   #8
ivstealth
Bimmercode and ncs. I use vgate on my bimmercode and an iPhone XR
      07-05-2020, 01:52 AM   #9
vangev
Australia
Can you please let me know steps/part in expert mode where you try to activate?
I don't main to try my self as well.
      07-05-2020, 11:07 AM   #10
ivstealth
When I put everything back to normal, it didn't work. It might be a problem with bimmercode and it made the button stop working through an error
      07-06-2020, 01:47 AM   #11
vangev
Australia
i just like to know which MODULE and SECTION is for trunk opening/closing operation? Error is hidden somewhere in function values (as: aktiv / Werte=01 or nicht_aktiv / Werte=00).
      07-14-2020, 01:19 AM   #12
ivstealth
No idea, I don't have an x5 only code sometimes. I don't touch x5 diesels anymore for this reason .
