      09-12-2020, 05:12 AM   #1
FloM
Drives: 2008 X5 / 2006 E90
Question 2008 x5 3.0d Servotronic valve
Hi all,
I have been scrolling this forum for a while...very useful info. Thanks to all of you that share different problems and suggestions!
Now is my time to ask. I have a 2008 X5 3.0d and about a couple of weeks ago i did a rapid scan with ista and got the following error “00A735 JBE: E9x: activation Servotronic valve: activation path 1; E7x activation, ECO valve”
I have changed the servo fuel, and clean the pump, reset the error code and everything was fine for about 3 weeks....(checked at around 3 days with ista)
A few days ago just checked again and have the same error plus: “ 00A736 JBE: E9x: activation Servotronic valve: activation path 2; E7x activation, ECO valve”
Now seems that both paths have a problem. And the codes are slightly different 735 and 736
Have to mention that both error codes are present!
I have done a search and ECO valve is a component part of the steering pump...should I replace the steering pump?
Any suggestions will be much appreciated!!!
Thanks for your time!
      09-21-2020, 07:18 AM   #2
FloM
***update***
Changed again the servo fluid last week...took out the servo pump and cleaned again (on my first attempt didn’t took out the pump)...reset the errors
So far (7 days) no error recorded...
Fingers crossed
Nice day!
