      08-27-2014, 02:46 PM   #1
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Grinding sound at startup
This issue has been heard several times before today but after I heard it again this morning I'm finally deciding to check with everyone here to see if this is a known symptom for something I need to have looked at.
It happens maybe once or twice a month immediately during startup, usually on cold starts. It sounds like something is grinding very LOUD, and lasts for maybe 2-3 seconds. Because it doesn't happen that often (and when it does it scares the shit out of me), I'm never prepared to check where the source of the noise is coming from.
Anyone had a similar experience with their X5M? Obviously I can't take it to the dealer and have them replicate the problem, so I'm not sure what to do about it.
      08-27-2014, 06:18 PM   #2
JVX6M
JVX6M's Avatar
Drives: 2023 BMW M3 Comp
I think I have heard what u experienced a few totally random times. The only way I can describe what I have heard was like if you tried starting an already started car. If that makes any sense I think we have all done it once or twice making that horrible grinding sound. I have heard it on both my E70's.
      08-27-2014, 08:24 PM   #3
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
I get this brief sound occasionally, too. It's almost like a heat shield rattling. I'd really like to get it sorted before my warranty expires in November!
      08-27-2014, 08:25 PM   #4
Poppyboy
2011 X5  [10.00]
I thought about recording it on my phone each time I start the car. If I'm able to catch it, I'd play it for the service technician...
      08-27-2014, 10:13 PM   #5
godmans
Drives: 135i / 335i / X6M
Also got the same thing in winter but was never able to repeat it for service.
I found some correlation between battery charge level (low) and the starting grind noise; might be worth a try for folks that also experience the same.
Lastly, as noted above, this seems to be more of an issue during cold start during cold times.
      08-28-2014, 07:47 AM   #6
Poppyboy
2011 X5  [10.00]
That makes sense (low battery), because it generally happens when I haven't driven in a while. I wonder if its the starter/bendix drive...
      08-28-2014, 10:22 AM   #7
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Try starting your X5 with the A/C turned OFF. Notice a difference?
      08-28-2014, 03:33 PM   #8
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Yes that's 100% what the noise sounds like! Good to know I'm not the only one that's heard this.
      08-28-2014, 03:59 PM   #9
Poppyboy
2011 X5  [10.00]
The A/C is always on when I start the car. I believe this issue was discussed in a previous posting. I think it was determined there's nothing that can be done to keep the A/C from being on when starting (including memory, etc.).
      08-31-2014, 11:36 PM   #10
Poppyboy
2011 X5  [10.00]
I saw something from a search about it possibly being a faulty X-Drive Servo-Motor. I have no idea what that is.
      09-09-2015, 07:09 PM   #11
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
While this is an E53, that's not to say BMW didn't carry the same design over to the E70. Is this what you guys are hearing? This hasn't happened to me, but i haven't had my X5M over a winter yet either.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      09-10-2015, 06:55 AM   #12
Poppyboy
2011 X5  [10.00]
No. It's a very brief, but loud grinding noise at start, very likely coming from the starter below.
      09-10-2015, 10:39 AM   #13
X Driver
X Driver's Avatar
Switzerland
70
Drives: X5M Black Fire Edition
Is the starter, dont worry, didn't really destroy it.. Just live with it..
      09-10-2015, 10:45 AM   #14
Crazy1323
Drives: X5M
My Audi had a similar sound on cold starts. The 4.2 in my Audi used timing chains on the back of the engine instead of belts. Our X5's use chains as well. If the tensioners have not had time to pressurize, you could hear some noise from the chains.
      09-10-2015, 11:05 AM   #15
X Driver
X Driver's Avatar
Switzerland
70
But this would be bad, and it does Sound different.. there you can hear the chain hit the Aluminium from inside.
      09-10-2015, 03:16 PM   #16
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
I've noticed mine has made this noise a few times recently on cold-starts. Probably 3 times on the past week versus once every 4-5 months... Very strange.
      09-10-2015, 03:54 PM   #17
X Driver
X Driver's Avatar
Switzerland
70
Maybe you have to replace the starter..
      10-27-2015, 09:36 AM   #18
Poppyboy
2011 X5  [10.00]
With the cold weather creeping in, has this started happening with anyone again? I've had a couple of noisy starts...
      10-27-2015, 09:49 AM   #19
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
I had mine looked at and they ended up replacing the starter. Since then I haven't heard the noise.
      10-27-2015, 10:39 AM   #20
Poppyboy
2011 X5  [10.00]
That's nice for you. I mentioned it a couple of times to the SA while under warranty. The technicians weren't able to replicate it. The SA said they would "take care of me" if it comes up again. Fortunately for them, my warranty expired last November. When the noises started again, earlier this year, subsequent messages to the SA mgr. went unreturned.
      10-28-2015, 06:07 AM   #21
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
It's the starter backlash it sometimes is slow to return I have on both my x5 and 550 it's normal
      10-28-2015, 12:59 PM   #22
Poppyboy
2011 X5  [10.00]
Thanks. That's somewhat consoling.
