06-30-2014, 05:09 PM | #1 |
BimmerPost Supporting Vendor
8067
Rep 18,788
Weight of F80 M3 / F82 M4 Lithium Battery
Had a chance to pull the Lithium battery from a F82 M4 over the weekend, quite a bit of weight was shaved off the previous AGM version:
Part: 61.21.9.312.759 Price: Not yet listed in system Specs: 12V 69Ah 770A/860CCA Lithium Original 30lbs shed just from the battery alone. System uses a different IBS connector and vent tube than the E9X M3, doubt a swap would be suitable for previous M3 models. However, the footprint is the same, keeping AGM/Lead Acid batteries an open possibility for budget-conscious as lithium type batteries can be $$.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
06-30-2014, 05:16 PM | #2 |
Rep 4,145
I just read an article about the batteries. Claimed they are $1100 plus change. I'll have to find it again.
Cheers.
2017 F80 YMB.
06-30-2014, 05:21 PM | #3 | |
8067
Rep 18,788
06-30-2014, 05:33 PM | #5 |
Rep 2,216
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
Thanks for the update Tom.
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
06-30-2014, 05:46 PM | #6 |
10723
Rep 27,536
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
06-30-2014, 05:58 PM | #7 |
Law Enforcer
24829
Rep 22,229
Drives: '22 Chalk Gray Porsche C2S
06-30-2014, 06:07 PM | #8 |
8067
Rep 18,788
Most definitely if you're comparing static mass. Rotating may be a different story.
06-30-2014, 06:10 PM | #9 |
Law Enforcer
24829
Rep 22,229
06-30-2014, 06:17 PM | #10 |
10723
Rep 27,536
I waited till 1015 for you! lol then I had to get on the road, wanted to beat the traffic. But yea got everything installed from EAS and it turned out very nice. Looks so good IMO I am very happy. Just need to get the car lowered it looks like a xM4
06-30-2014, 06:18 PM | #11 |
Law Enforcer
24829
Rep 22,229
Now I have a reason to roll up to your area.
06-30-2014, 06:21 PM | #12 |
10723
Rep 27,536
^^No doubt! Solvang is always a good time and a great get away if you guys are ever looking for something to do.
06-30-2014, 08:34 PM | #13 |
Rep 1,268
$1,100 a pop is insane!! I do like they have saved 30lbs though.
Past: BMW (22 G20 M340i, 15 F80 ///M3, 12 E92 335i, 08 E90 335i, 02 E46 325i)
Mercedes-Benz, Porsche, VW, Lexus Present: 24 992 C2 |
06-30-2014, 09:28 PM | #14 |
Rep 2,995
That price will come down in 4 years. And there's other batteries that will be suitable, nearly 30 pounds in total weight, and only a few hundred dollars at a pop.
For $1100, you could go with a much lighter weight battery if you wanted. My only question, due to lack of understanding on my part, is whether the electronics would require the LI-ION battery for any reason. |
06-30-2014, 10:11 PM | #17 |
Rep 4,145
They said something like, when the battery sees greater than 14 volts it goes into "save the battery mode" and kind of shuts itself down, or something. So, maybe this is why not.
However, there is a section in the manual about jump starting. Preparation is: 1) Check battery of vehicle offering the jump to make sure it is 12 V. 2) Switch engine off of vehicle offering the jump. 3) Switch off electronic consumers in the offering vehicle. I guess as long as it is not over 14 Volts then all is fine. Cheers.
2017 F80 YMB.
07-01-2014, 06:59 AM | #18 |
Rep 2,995
Jumping a car from another car is very safe (provided you connect the terminals safely). The more....risky....stuff is jumping from a portable starter. Those can have voltages/amps all over the place.
07-01-2014, 09:24 AM | #19 | |
Rep 1,997
(My EE bachelor's is getting rusty so forgive my 'old' knowledge as I don't even use it for my current job...) |
07-01-2014, 11:45 AM | #20 | |
Rep 210
I'm hoping that the car can detect the presence of a lead acid battery automatically or be instructed via coding. I don't see the $1100 price tag dropping very soon; this is a niche battery that won't see mainstream adoption. When a standard H6 lead acid replacement battery is $90, I don't see myself personally getting $1000+ worth of value from saving 30 lbs with the Li-ion unit. |
07-02-2014, 09:12 AM | #21 | |
Rep 1,997
I do see the price coming down but probably now south of $500 anytime soon. I wonder if it provides any other benefit than weight, I'd hope it would last longer, but I suspect that isnt the case. Just thinking how mobile electronics are moving to that type of battery so it would lead me to hope that since it's not cutting edge technology the price should come down to more reasonable levels once there are enough applications. If this is the only one for awhile there really is no reason for the manufacturers (which will be limited) to lower the price. Cue supply/demand mantra. |
07-02-2014, 09:21 AM | #22 |
Rep 2,995
People: You can buy a 30-40 pound lead acid battery with a great CCA rating and reserve power for less than $200. It may not have the lifespan or reserve capacity or super-cold starting ability of this LI-ION battery, but that's a choice you can make.
You don't NEED to buy a $1100 LI-ION battery to get a 30 pound battery capable of starting the car (unless BMW deliberately engineered it that way). Heck, there are really really really lightweight batteries that will operate the M3 and will be great for racing applications (i.e. 11 pound batteries). I'd like to understand the expected lifespan of this battery though. |
Tags |
battery, eas, lithium, weight |
