BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      09-19-2012, 10:33 PM   #1
JamesKilcarr
Drives: 2011 jet black e92 m3
best 295 rear tire? e92 m3
hi guys i currently have a 295/30/19 rear tire on my e92 and it rubs slightly while hitting big bumps, does anyone know the best tire performance wise for that size that will not rub or rub very slightly like it does now, the car is not lowered at all
thanks
      09-19-2012, 11:06 PM   #2
mark896
Warrant Officer
mark896's Avatar
Drives: 2011 E92 335is
Do you have spacers? I've heard that the Michelin PSS 295/30/19's are a perfect fit if you are on ZCP rims.
      09-20-2012, 07:53 AM   #3
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
What tire/wheel combo are you running?
      09-20-2012, 08:45 AM   #4
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
I just trimmed my fender liner a bit to get 295/30/19 AD08 to fit at full compression lowered on coilovers. It only took a few minutes with a dremel, and nobody would ever notice unless they were inspecting the fender liner with the wheel off.
      09-20-2012, 08:53 AM   #5
Alex07M3
Drives: E92 M3, Evo X MR, A4 Allroad
I have AD08s on my ZCPs, my car is an 08(not ZCP) and I'm lowered with Eibachs, not rubbing!
      09-20-2012, 09:18 AM   #6
Porschefile
59
Drives: E92 M3
I didn't expect to have to trim it. I can tell you from experience that there is some variance between each individual M3. I'm not crazy low, roughly zero fender gap rear, or possibly a few mm tuck.
Not that I'm bitching about it, I mean it is normal to have some variance in a mass produced vehicle. But I can tell you that mine rubbed until I trimmed the fender liner. And the wheels and tires I'm running did not rub on a different E92 M3 running H&R springs.
      09-20-2012, 10:10 AM   #7
JamesKilcarr
I have vmr 710 wheels with 11 in onthe rear with 25 offset and a 295/30/19 bridgestone potenza tire and a 255/35/19 on the front on a 9.5 rim
      09-20-2012, 10:12 AM   #8
JamesKilcarr
Which part did you trim? Thanks for the help btw, it rubs on mine on like a plastic nub thing that sticks down, would you happen to have a pic of the part you trimmed it would be a big help
      09-20-2012, 10:13 AM   #9
JamesKilcarr
I dont have spacers and i have vmw 719 rims 9.5 front and 11 rear
      09-20-2012, 11:20 AM   #10
Porschefile
59
Drives: E92 M3
I trimmed the plastic that sticks out, on the right rear it is toward the rear bumper/fender. It's hard to describe in words I guess. No pics, sorry.
      09-20-2012, 12:37 PM   #11
BMW Fanatic
Drives: slow
I am also running VMR's. 19x10 in the front and 19x11 in the back, 265/30/19 and 295/30/19 no rubbing at all, never even experienced it with this car. Tires are Hankook Ventus V12. I'm also on the ZCP drop which is about 10mm.
I assume you are running the RE050A or the S-04 Pole Position? Which is weird considering Alex07M3 runs AD08 295's which generally run wider than most other tires. I'd say you ordered +25 offset wheels but were given +20. I don't see any other reason for this to happen especially on a stock car. I plan on lowering mine and with enough negative camber it shouldn't rub then either.
      09-20-2012, 05:07 PM   #12
lm1z
lm1z's Avatar
194
Drives: 2017 GT350
I've had success with Nitto's, both the Invo's and the NT-05's. Ran a 305 on a +25 and rubbed very slightly in the beginning with a loaded car. Running a 295 on a +22 with no issues.
PAST 2007 Black Sapphire E90 335i, 2010 Jerez Black E92 M3, 2012 Mineral White E92 M3, 2013 Singapore Grey F10 M5, 2016 Azurite Black F80 M3,
CURRENT 2017 Oxford White GT350
      09-20-2012, 07:02 PM   #13
///M Ryder
Grown Azz Man
///M Ryder's Avatar
Drives: GT4
PSS 295-30 on ZCP wheels......no rubbing at all............Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
      04-18-2013, 08:01 AM   #14
M Tres
Drives: 2008 AW/FR E92 M3 Coupe
What PSS tire size are you running up front on ZCPs? I have ZCP wheels and want to put on the widest tires front and back without rubbing. Thanks.
      04-18-2013, 08:10 AM   #15
JDM3
JDM3's Avatar
109
Drives: 2009 M3 E92
Morr wheels 19x10 with Toyo R888 295/30/19 on Eibachs.....no rub but its very close!
      04-18-2013, 08:22 AM   #16
///M Ryder
Grown Azz Man
///M Ryder's Avatar
Drives: GT4
When I had the ZCP wheels on I was running a 265-30 up front..........Phil
      04-19-2013, 11:55 PM   #17
jra85
M3NTAL
jra85's Avatar
Drives: 2011 E92 M3 ZCP
I just put 275/295s on my E92 ZCP (stock height), absolutely no rubbing and it grips incredibly.
      04-22-2013, 05:13 PM   #18
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
295/30r19 AD08s on 19x10.5 ET25 rubs. It just barely rubs on the little protrusion of fender liner but I don't want to cut it, so switching to a 275/35r19 rear.
      02-17-2014, 02:30 PM   #19
Kurt_OH
Kurt_OH's Avatar
Drives: E90 M3 ZCP
Can you please share the rest of the tire info?
Brand/model, aspect ratio.
I'd love to run 275 / 295 and I'm thinking the PSS 275/30/ZR19 and 295/30/ZR19 look like a good set. Is that what you're running, stock?
... a glorious V8 that screamed and hollered as the revs rose and then howled in an orgy of what sounded like BDSM ecstasy as it neared the red line.
Well, you can forget all that. The new car is fitted with a turbocharged straight six. Turbocharging? In an M car? That’s like putting gravy on an ice cream.
- Jeremy Clarkson, discussing the S65 and then S55 M3 engines.
      02-17-2014, 04:14 PM   #20
jra85
M3NTAL
jra85's Avatar
I replied to your PM Kurt with some more insight but yes they are PSS tires with the same spec you described, on my stock E92 ZCP. Forum member 4sevens.com has run this same combo on his stock E90 ZCP in the past with no issues either.
      02-24-2014, 05:45 PM   #21
flea333
flea333's Avatar
Drives: 2013 M3 ZCP, LMB, DCT
2008 328i  [0.00]
did you notice any gas mileage reduction? i've heard more rubber will tear up your mpg
2013 M3 LMB, DCT, ZCP, Premium, EPS, Bamboo Beige, Apps, sunroof
      02-25-2014, 08:23 AM   #22
jra85
M3NTAL
jra85's Avatar
Haven't really kept notice honestly. I would maybe expect a very slight decrease in MPG due to the shorter tire diameter over stock (higher RPMs required to match the same speed as that of a taller tire), but I definitely haven't noticed any significant difference.
Tags
lowered, performance tires, tires, vmr wheel, wheels
m3post
