      09-24-2017, 06:00 PM   #1
Bmwlover x
Drives: X6
Want white angel eyes instead of yellow
Hello. Want to change angel eye bulbs. Need white ones and also need white fog lights. Which one to buy? Do not want to see any light errors when I check my car with dealer software.
      09-24-2017, 10:47 PM   #2
Tacticalx3M40i
Drives: 2018 X3m40i
sure, buy a 2012 or newer. I remember the days when we said Halogen rather than yellow.
      09-24-2017, 11:21 PM   #3
P1
P1's Avatar
11568
Drives: 2004 3/4 ton Duramax
You can buy the PIAA ones. Had those on my 2011 X5 and 2011 135i. Made it a lot whiter. Just don't waste your money on LED.
      09-25-2017, 02:57 AM   #4
Bmwlover x
Drives: X6
P1et
was not able to find piaa light bulbs for x6.
YelloSno80
My car is produced in 2013 but its angel and fog lights are yellow. Want to be white as there is shown
. Some people say that after changing halogen and inserted there white ones, had error codes. Do not want error codes too. Can you post a link from ebay which lights are the best? Thank you.
      09-30-2017, 04:45 PM   #5
peter2772000
Drives: 2012 X6 35i Sport
I & others have swapped out LED bulbs and now have white angel eyes. No error codes either Did you not do a search b4 asking this question?
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      10-01-2017, 05:38 PM   #6
Bmwlover x
Drives: X6
Sorry did not understand about b4.
Can you please give me link which lights you installed. Do not have errors when check from bmw software? (for example ista d) maybe you coded it for disabling error codes?
      10-02-2017, 05:52 AM   #7
peter2772000
I think this is called hot-linking, which is frowned upon by some sites and not by others. Moderator, lemme know if this is forbidden here.
https://www.luxangeleyes.com/products/lux-h8-180
I purchased the older H8-160 awhile back, no codes or issues at all. The 180 is the successor to the 160.
One of the complaints by some was that with the 160, the rings weren't both the same brightness. While true, it wasn't enough of a difference o bother me personally.
Hopefully, these updated versions also turn into position more than the 160. With the 160, you can tell that they won't rotate as much as the OEM bulbs, giving you the impression that they might fall out over time. They don't, but it's still a bit disconcerting for me.
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      10-23-2017, 10:28 PM   #8
zhp2m3
zhp2m3's Avatar
Drives: M2
I've been using LUX angels eyes for years. Both in my E90 M3 and E70 X5. Only issue I had was with the 160's one of the bulbs went out. I contacted LUX and they sent me another pair. Now I have the latest 180's and they are better quality with a nice "led" white look.
      11-05-2017, 09:30 AM   #9
Frankkao14
Drives: 2012 BMW X6 50i
Get LUX angel eyes
