      01-08-2019, 03:59 PM   #1
AaronLG
Drives: None
Door lock issues
I've been searching nonstop but can't seem to find anything similar to my issue. The driver and passenger door will not unlock or lock from the key fob or center dash button. If I press the lock indicator on the door down it will stay locked but won't unlock unless I use the key on the driver door or open the passenger door. I have soft close doors. The back doors work fine and the alarm sets. The doors also close just fine. I've checked every fuse and replaced every fuse that has to do with the doors but still have the issue. Any suggestions?!
      01-08-2019, 08:12 PM   #2
argento
argento's Avatar
538
Drives: 2013 X5M
Sounds unhelpful, but If it were me, I'd disconnect battery for 30m, then reconnect. If no-go, I'd swap out the center lock switch to at least rule that out. If no-go, then I'd have bmw recode locks. All the time I'd be elbow deep in those schematics on TIS.
GL and keep us posted!
