BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > HELP! 335i Persistent Code P2400
      04-12-2014, 02:38 AM   #1
michaelserom
Drives: LCI E90 335i
Exclamation HELP! 335i Persistent Code P2400
Hi guys,
I bought my car last March 26th, since then the car has had the CEL with the "P2400 code" come up at least 4 times now.
I am absolutely thrilled about the car, but seeing the CEL come on just ruins my day... Any help will be MUCH appreciated!
Car specs: Stock 2009 BMW E90 335i | 72,XXX KM / 44,XXX Miles
The first time (2 days after purchase) I took it back to the dealer he said it could have been a loose gas cap, and so he cleared the code for me and showed me how to "properly" insure the cap was closed after filling up gas... however at the time I had yet to fill up gas since the purchasing the car... weird...
3 days after I got the CEL again, and decided to purchase my own OBD2 reader to scan the code; Again "P2400" I checked the gas cap and there was no way it was loose.
Whatever I cleared the code and called a reputable local indy (Rocco @ RMP Motors) to book an appointment for a general check up.
Following my appointment @ RMP, I've had the DMTL pump replaced with a used one Rocco had sitting at the shop, as well as fixed some damaged wires connecting to the pump.
Throughout the time when the CEL was present/and after clearing I drove the car quite hard to test if any power was loss, none was. The car drove normally. However I did notice that the CEL (code P2400) tends to come on after driving the car semi aggressive... (DS mode) and only comes up after a drive, it has never poped up while driving; 3 times on a Cold Start, and once after 15-20 minutes of being parked.
My thought on the matter is to purchase a brand new OEM DMTL Pump + Gas cap, and have both installed, however I would feel REALLY bummed in the event the code was to come back...
Has anyone ever had the P2400 code come up constantly as well?
What have you done to resolve it, and how much did the bill total to?
So far I have spent $300, on this particular matter.
$100 OBD2 Reader
$200 Indy check up, replaced DMTL pump with used & new air filters.
Again I appreciate any input on the matter.
Thanks,
Michael
      04-18-2014, 06:28 PM   #2
michaelserom
Bump for input
      04-18-2014, 06:50 PM   #3
924er
Drives: e92 335i '10
Bad EVAP pump. They're in stock at the dealers and aftermarket parts places. Common issue.
      04-18-2014, 10:19 PM   #4
michaelserom
Hey thanks for the your input.
I guess the used one he put in was on its way out as well?
Anyways ill be purchasing a new pump and will report back when installed.
Thanks again!!
      04-19-2014, 11:49 AM   #5
Ingeniator
Ingeniator's Avatar
Drives: 07 335XI(90) 09 135I(82)
Thanks again!!
It could also be a clogged breather line to the pump. I would verify the lines are good before buying another pump.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system
      07-14-2014, 07:19 AM   #6
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
Hey OP, it's been a few months, but how are you making out? I started a similar thread back in February, and finally got around to installing the new DMTL pump over the weekend. The next day, took a drive to Newport,RI (roughly 50 mile round trip) with no issues.
The next morning (yesterday), however, I start my car to head to Bristol,RI for an e30 meet and bam, SES light is back on. I check codes and again, the P2400 code is back.
So I'm beyond annoyed that it looks like I spent $75ish on a new pump when that perhaps wasn't the issue, after all. Did you end up figuring out the cause of your issue? Need to try and diagnose why I keep getting mine, so I can get rid of my lovely, new Rejection sticker.
Thanks!
'05 BMW M3 6MT (Weekend car)
Need to stock up on some detailing products or spiff up your garage, then use my Obsessed Garage link!
      07-14-2014, 07:25 AM   #7
eforty6_m3
eforty6_m3's Avatar
Drives: '05 M3 6MT
2005 BMW M3  [0.00]
Thanks!
Tags
335i, code p2400, dmtl, n54, p2400
