      09-18-2023, 06:29 PM   #1
dayday57
Drives: BMW X5
Front Suspension bolts?
Hello, new to the forum, obviously the frustration of trying to find parts has brought me here. I used the search function with no luck.
Picked up a 2011 X5 and need to do some front suspension work. She spent some time in the Salt in Germany so I ran into some stuck bolts.
I’m looking for a front suspension diagram with the bolt part numbers available or for one of you smart fellas to help me out.
When trying to get to the strut, the “pinch” bolt that holds the upper ball joint to the top of the knuckle is seized and I want to replace them. Any leads on them or know the specs on the hardened bolt to and nut to get a new one?
Also want to replace the bolt and nut that attach the bottom of the strut fork.
Any help is appreciated.
      09-18-2023, 09:45 PM   #2
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
Realoem.com will be your best friend for part numbers
      09-18-2023, 10:26 PM   #3
dayday57
Drives: BMW X5
You are the real MVP!!! Thank you.
