      09-08-2023, 04:27 PM   #1
rfornell
Drives: 2011 X5M, 2014 335, 2001 740iL
Crankcase pipe collapsed brand new 5 miles on it
Quick question maybe, i have replaced this once before at about 120,000 miles, noticed a similar whistling noise a few days back at 192,000 and it was idling rough. Cracked again. New one came today installed it, took it for a spin across town I thought maybe it needed to reset the idle being that the part was leaking a lot. Got worse and when I got home I figured maybe I broke one the ends installing it or it had come unclipped. I thought the hose had a big hole in it but it is actually vacuumed flat so nothing can flow through it?
      09-16-2023, 11:06 AM   #2
Colodano
Drives: 2010 X5M
Did it pop back out once shut off? Sounds like there is another issue in the system, probably the check valve/s in the fresh air ducts.
I have had to replace mine 3 times in 60K miles, and the last one I wrapped in gold heat tape, will see if that helps longevity at all.
