      09-06-2023, 01:32 PM   #1
Jazzyj13
Patriot
Drives: 2013 X5 50i
Oil Level Sensor
Hello All. I have a question regarding the oil level sensor, when they fail are they more prone to showing no or low oil or do they indicate full.
      09-11-2023, 08:55 AM   #2
BXMMMMMW
Drives: X5M
2011 BMX X5M  [0.00]
I am pretty sure mine has failed as well. It is reading "Max" and has been for months. Before AND after I added 4 Liters. I have the new one, waiting for oil to arrive and I'll replace it and update. It should go above the Max line when filled to 10 Liters.
      09-11-2023, 11:18 AM   #3
Jazzyj13
Patriot
Drives: 2013 X5 50i
Thank you for the reply, hate there is no dipstick in these trucks. Will you be swapping out the oil pressure switch as well.
      09-12-2023, 05:46 PM   #4
dudezi
Drives: X5
I was told by SA that BMW did a software upgrade to disable “too much engine oil” warning . BMW told ppl burn engine oil is normal and recommend adding 2 qt when engine oil level is low.
