      06-06-2017, 07:31 PM   #1
95wildtt
Need mo $$s
95wildtt's Avatar
Drives: 2020 X4M Competition
Bricked TRSVC Module??
Hi,
I've been working on an RFK to TRSVC camera retrofit (I had a correctly working RFK camera except for it being in Black & White with my NBT EVO display) and have everything installed and the old module removed from the X5 (2008 4.8i).
I can't get the new TRSVC module (bought used off eBay Part# 9291386) to work correctly. Also, the PDC button blinks on/off when in reverse and there is no picture on the screen from the RV camera, although the camera controls are on the left side, and the PDC is working like normal (other than the blinking LED above the button). So the module is being seen by the system...
I have coded the various modules with the new FA (tried $3AG but then the both the RFK & TRSVC modules show in ISTA+) with $3AH and have the TRSVC module correctly reported in the tree in ISTA+... The module reports its info (part number, SW etc) correctly but I can't access, test it or reset it. I also can't read or write it in NCS, just as a another data point. I can access all of the other modules in the X5 and perform any type of diagnostics without any issues.
I've verified all of the wiring and power to the new TRSVC module several times, and since the module is seen in ISTA+ and reports its info correctly I believe the CAN connections are working OK.
Could the mdoule be "bricked" or damaged in some way so as to not work correctly? This seems very odd to me...
I have another TRSVC module on the way tomorrow (Part # 9236527) and will try to replace the first module with the new used one and see what the results are.
Will report back.
Any ideas/suggestions?
What modules should I have coded?
(I've coded CAS, FRM, IHKA, JBFF, PDC & KOMBI with the new FA)
Thanks,
John
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan
1995 Dodge Stealth TwinTurbo
Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport
      06-06-2017, 11:37 PM   #2
-c-
-c-'s Avatar
Drives: bmw
Originally Posted by 95wildtt View Post
Hi,
Will report back.
Thanks,
John
What kind of retrofit is this? Sorry so many acronyms!
      06-07-2017, 07:40 AM   #3
95wildtt
Need mo $$s
95wildtt's Avatar
I know, but it's a Rear View Camera from the original (RFK) in my 2008 4.8 to a newer version (TRSVC) for use with my NBT EVO.
Thanks,
John
2020 Porsche Macan
      06-10-2017, 08:19 AM   #4
95wildtt
Need mo $$s
95wildtt's Avatar
Update:
In case anyone else has these issues...
Note that if you are working with a Pre-LCI X5, as I was, you also must do the folllowing:
1. Replace the JBBF (Junction Box module under the glove box) with a newer LCI module
2. Extend all of the PDC sensor wires from the old PDC in the Left rear area to the new JBBF module (which has the PDC built into it)
3. Remove the old PDC module
4. Code the new JBB module
Enjoy,
John
2020 Porsche Macan
