02-23-2015, 07:35 PM | #1 |
Rep 123
Anyone Track their X5M
If so, impressions. Are there any track brake pad compounds for this truck? How about camber plates or other adjustments for front camber. Are KW3 the only coilover available? What's the widest tire anyone has stuffed in the front?
Thanks for your input. |
02-23-2015, 09:19 PM | #2 |
Rep 1,547
Drives: '22 Tesla MY + '23 Tesla MY
Not sure if serious.
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
02-23-2015, 09:57 PM | #3 | |
Rep 565
02-23-2015, 11:33 PM | #4 |
Rep 994
KW v3's and a cheap Taiwanese coilover from D2.
No camber plates that I know of, though BMW makes camber arms in -0.5, 0.0, and +0.5 deg increments for the fronts. Usually used after an accident. At the end of the day, it's probably the worst car to run at a track, unless this is a one-off effort. too heavy, high CoG, and too heavy. :-P |
02-24-2015, 12:38 AM | #5 | |
Rep 123
I got the X5M partially as insurance if my Miata experienced a breakdown at a HPDE event. Hate to waste a paid weekend. Why not roll up to the grid in a steroid pumping grocery getter and embarrass half the cars there. Wanted to get more opinions from those who have tracked theirs. Clearly the brakes are the weak link. And front camber adjustment. Fluid, track pads and a square setup would help. A tune would make it competitive on the straights but exacerbate braking issues. I have no illusions that this truck can take a 30 minute pounding without issues. I would set the horses free for a couple hard laps and bring her home early. |
02-24-2015, 09:43 AM | #6 |
Rep 123
What is the widest tire anyone has stuffed in front? If I can find a good deal I might get another set of rear wheels and tires (299) and put those up front. With a 35et offset, the stock 11" rear wheel, with a 315 tire, would be 25mm closer to the fender, which would probably stick our a little past the fender. Shouldn't be an issue on even a slightly lowered suspension. Open question is do I have 15mm of clearance towards the strut. Probably. I'll need to measure.
02-24-2015, 05:19 PM | #7 |
Rep 60
I've tracked my 2010 X5M twice at Texas World Speedway. It is absolutely a blast to drive around the track and very capable. Amazing how well it handles and how fast it is in the straights! I am all stock. The oil temperature gauge never even hit 210F. The brakes get a little bit glazed over towards the end of the day but never had any serious fade after 3x30 minute sessions. Top speed was about 135 in the main straight and 110 in the back straight!
02-24-2015, 05:37 PM | #9 | |
Rep 123
Any mods for the track? What organization did you run with? |
02-24-2015, 05:43 PM | #10 |
Rep 60
Both times I've gone with the Houston M-club and it's been great (relatively small group of cars so not a lot of traffic). I'm in the beginner class, only track experience is with the X5M and its awesome! I do wonder how much fun it would be with a lighter vehicle, but the X5M has its own charm being out there.
It's unfortunate that this track will be closing later this year, so I've heard. No I haven't done any modifications, just gas it up and take out anything that will fly around. Then drive it home and to work the next day with no issues! |
02-24-2015, 06:39 PM | #11 |
Rep 123
Yes, TWS is closing but a new track is on the board near Brenham. If it happens it would open in the fall or early 2016. I have an event April 11-12 at MSR Houston. Ever driven that track?
02-24-2015, 07:04 PM | #13 | |
Rep 123
02-24-2015, 07:06 PM | #14 | |
Rep 123
02-24-2015, 08:17 PM | #15 |
Rep 691
OP, I ran 295's up from and 335s in the rear on a 22 inch wheel. Pirelli is one of the few that makes it in those sizes, they have a high performance summer and all season option in that size.
To anyone who thinks tracking an x5m is stupid, keep in mind the whole reason this truck has an M badge on it is for that very reason. You CAN take it to a track and have a lot of fun. It will out do some very capable cars. There was another member on here who tracked his M daily, he actually used it to instruct people on the track. He had another track spec vehicle but said that the x5m was truly an impressive machine on the track
2012 X5M Monte Carlo Blue/Black-SOLD
Velos Stage 2/Velos Catless downpipes/Dinan exhaust/Dinan Suspension 2018 M6 Gran Coupe Competition- Singapore Grey/Aragon Brown DME Stage 3 |
02-24-2015, 09:44 PM | #16 | |
Rep 123
02-24-2015, 10:58 PM | #17 | |
Rep 994
It wasn't for the track, though semi track capable on HPDE, but not much more beyond that. Simple physics. For anyone that has truly tracked a car, they would know that a 5k+ car/SUV/SAV will never be a successful track vehicle. But an occasional romp has never hurt anyone, other than their wallet. |
02-25-2015, 08:23 AM | #18 | ||
Rep 123
02-25-2015, 09:34 PM | #19 | |
Rep 691
02-25-2015, 09:38 PM | #20 |
Rep 691
Those are kept private by most manufacturers for some reason. You might get the info if you poke around with a few vendors but I could not. 22x12 in the rear and 22x10.5 up front, no idea on offsets like I mentioned but if you are getting a set made for the x5m it will be pretty much flush with the fender. No spacer required
02-25-2015, 10:29 PM | #21 | |
Rep 40
02-28-2015, 11:15 AM | #22 |
Rep 123
