      03-09-2015, 11:45 PM   #1
HPIA4v2
Drives: F80, F86
trying to remove 2011 X6 passenger side headlamp
do I need to remove the front panel to remove the headlamp assembly?
But how about door and foot-board(running board).
Appreciate any tip, thanks in advance
      03-10-2015, 12:41 AM   #2
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
You will need to:
- remove one of the front wheels
- remove front fender wheel liner
- remove plastic frame support triangle
- remove headlamp assembly
      03-10-2015, 07:54 AM   #3
HPIA4v2
Drives: F80, F86
so Igor, you access the headlamp assembly from under the fender or wheel-well?
I don't need to remove the fender itself, right?
Will try this, but how do you access the 4 screws(#13 in the picture) from the back of head assembly?
pardon my many questions, but I never seen a car that require so much work to just remove a headlight
I know you've done this, thanks for answering.
      03-11-2015, 09:53 PM   #4
HPIA4v2
Drives: F80, F86
OK, got it. should've listened to Igor
