      11-21-2017, 01:33 PM   #1
esevx5
Drives: X5
Replacing one rear tire with a new one?
edit
      11-22-2017, 07:05 AM   #2
coolmayank
Drives: X5m
Originally Posted by esevx5 View Post
Hey guys,
I ended up damaging the sidewall on my rear tire and have to replace it.
I understand that it's best to replace in pairs but my rears were brand new with little mileage on them.
My question is, can I replace the damaged one with a brand new identical tire?
The tires had exactly 3410 miles on it, of which 2200 miles was highway driven across the country in a single trip.
Does 3400 miles make a difference in overall diameter?
The best way to know if it has affected the
diameter is to get a tire tread gauge for 3-4$ and measure the tread gauge and than you can check what was the new tread size on tire rack or some other site
For example the continental RFT comes as 9/32” when new and the Bridgestone was 11/32”.. but again each tire is different
      11-22-2017, 07:47 AM   #3
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
If the new tire’s tread depth is within spec of the used one, often 1%, you should be ok. Check the tire manufacturer. If out of spec, you can have the new tire shaved down to match.
      11-23-2017, 01:11 AM   #4
fsd350
fsd350's Avatar
Drives: 2010 BMW 335d
You will be fine. I seem to remember that 3/32" is within tolerance. 3,400 miles is not much to affect treadwear. I lost a fairly new tire with our X and a QT Jeep before that with no issues at 3/32" tread depth variance.
      02-25-2018, 08:04 AM   #5
celluloidheros
Drives: 2013 x5 5.0
you will be fine, unless you want to buy two and try to rotate in a 3rd which will be a PITA
