      07-09-2011, 10:53 AM   #1
Copperprince
Hi,everybody.
Thailand
Drives: BMW X5 e70 3.0d 2011
Smile How to remove rivet plastics when change fender arch wheel?
I want to know.How to remove rivet plastics when change fender arch wheel.thank you.
      07-09-2011, 04:14 PM   #2
263464757
Lt. General
263464757's Avatar
Drives: X5 5.0, 540i, 1965 C2
Take a small punch and just push out the center, then pull the washer portion out...easy...
There just like a standard pop-rivet only "plastic" and the center pushes back through. Replace with a new one.
Also, take note of the size of the ones your replacing... theirs a couple of different sizes used between the front and rear. It took my parts guy a couple of times running back and forth to get the right ones...
