      08-19-2018, 12:33 AM   #1
e70jane
e70jane's Avatar
Drives: bmw e70
Talking E70 N62 Rocker Arm Fallen
Been chasing a hesitation problem for the past 6 months. Multiple CAN faults and cel are present. Stealership replaced negative battery cable and ibs but no difference. Searched all over for a short but couldn't find any. Replaced alternator, pointless. Checked Vanos, all working. Replaced driver side Valvetronic actuator due to fluctuating ohms value on multimeter, wasn't the problem. Finally, what I hoped not to perform, replace eccentric shaft sensors. So today I removed the driver side valve cover and removed eccentric sensor. Nothing unusual, connector and beneath the square metal plate was free of oil. However, I discovered a fallen rocker arm. Now I'm quite confident that all along, this was the culprit! Now, how bad of a job would it be to reinstall the rocker piece?
      08-22-2018, 10:42 PM   #2
e70jane
e70jane's Avatar
Drives: bmw e70
This is the part that fell off and was bouncing around inside the valve cover.
Is the AGA tool a must to put this part back in place?
      08-24-2018, 09:33 AM   #3
heatmizr
Drives: E70 X5 50i M-Sport
Wow!! Had no idea these could just fall off!
Following...
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      08-26-2018, 01:28 AM   #4
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
You can put them back in you just need to turn the motor over to a point where the cam puts as little tension as you can on that rocker and use a pick. It's a pain in the ass and you need to be careful but it can be done. Interesting that it tossed one out on its own though-I've only seen that happen during reassembly for repairs that they come out...
      09-25-2018, 02:14 PM   #5
e70jane
e70jane's Avatar
Drives: bmw e70
I already put it back on but before I start it up, I will first change the oil from 10w40 (euro formula) back to 5w30. I'm wondering if the thicker oil was the cause for the lash adjuster to freeze up, hence the rocker arm falling off. I inspected the spring and all looks fine, nothing broken. I'm also hoping and praying to god it's not a bent valve. Any case, wish me luck..
      09-25-2018, 03:21 PM   #6
heatmizr
Doubtful that the oil caused it, how much difference can there be between those two similar spec oils?
heatmizr [Todd]
e90 328i - sold
      08-13-2019, 03:06 PM   #7
gentooguy
gentooguy's Avatar
Drives: 2007 BMW 335i Alpine White
I apparently have the same issue with my E70 N62 X5. I am getting a constant misfire on cylinder 8. My valvetronic's motor spring snapped prior to the constant misfire and I had to replace. Aligned with ISTA and thought everything was fine. Still misfire on cylinder 8. Took off valve cover and found these parts bouncing around in the top of the engine near cylinder 8. Changed the oil and found a couple of the smaller parts in the old oil. Guessing they fell down the oil drain ports. Still haven't attempted to fix this yet debating what to do. Was thinking to replace the broken rocker arm tow lever and then drop the oil pan to make sure there is no leftover metal pieces. Hopefully that will solve. Please help.
You can see in the photo once of the ears broke off the rocker arm tow lever.
      10-30-2020, 11:06 AM   #8
gentooguy
gentooguy's Avatar
I got the intermediate lever can these be placed back in without taking apart the top valvetronic part of the engine?
