      12-10-2013, 08:57 AM   #1
blue dragon
Drives: '22 Tesla MY + '23 Tesla MY
LCI headlight retrofit
I had some spare time on Saturday, so I did it
I cannot take credit for figuring it out, I followed someone else's guide
I did leave it so the corona rings don't dim at night, they are super bright.....
I had already done the LCI tail lights with rear fog lights enabled a while back (old picture)
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
      12-10-2013, 03:28 PM   #2
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Very nice! How long did it take you to do the swap?
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      12-10-2013, 03:54 PM   #3
blue dragon
^^ It took about 5 hours including coding. The majority of it was spent struggling to get lower bracket that supports the headlight out. Its held on by two 8 mm bolts at the top (removable from the engine bay), but the lower bolt which bolts to the headlight is only removable after removing the fender liner. After removing those, there are a couple other bolts holding the bracket, and then you have have to slide the bracket down and out, except there almost isn't enough space to do this.
Once you get the bracket out, its four bolts holding the headlight, and it comes out easily.
For coding, I used WinKFP to write the VIN to the new FRM. Then I used NCSExpert in expert profile mode to write the FA (FA write) to the FRM. Then I coded it with SG coderien to default the module.
Then I coded it using my editing profile that allows for manipulation, and I changed the order date to #0411 and coded the FRM. I also coded things like foglights on with high beams, and high beam flash, double blink etc
      12-10-2013, 08:13 PM   #4
larryv
larryv's Avatar
64
Drives: 17 M3 ZCP 11X5 M Sport 20 I3
Came out great! What can't you do?
      12-10-2013, 08:31 PM   #5
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
+1 looks awesome!
Where did you end up buying the lights, if you don't mind me asking?
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      12-10-2013, 09:39 PM   #6
Kakalika
Kakalika's Avatar
Drives: 2014 X5 35d M Sport
I have great faith in you.
RUN FLAT TIRES? NEIN DANKE!
      12-10-2013, 10:11 PM   #7
blue dragon
I ended up buying parts on Ebay and piecing together the headlights, otherwise, it was too expensive. Complete headlights sell for about $1000 a piece. If you buy the parts and assemble them, you can do it for about $600.
The FRM3 was bought from Morristown BMW for $260.
      12-13-2013, 09:20 AM   #8
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Great work, this is really the only "proper" upgrade for us who still rock the old headlights. Hats off to you sir!
      12-13-2013, 09:41 AM   #9
IGotId
IGotId's Avatar
23
Drives: '10 X5 M
Very nice!
      02-15-2016, 01:07 PM   #10
gixxerboy63
Tanzanite Blue II X5M Pilot
gixxerboy63's Avatar
1047
Drives: M3, M4, X3 M40i, X5M
2017 m4  [0.00]
2010 BMW X5M  [10.00]
Reviving old thread....
Recently retrofitted LCI headlights in 2010 X5d (build date 11/09).
Has original FRM3. Had BMW update all modules (02/16) prior to installing headlights
Before coding, everything seemed to work (except the corona rings were flickering)... while coding with Autologic, the corona rings immediately went full bright, but now I have no high beams, the adaptive headlights do not work and the CIC display is showing a whole list of lighting error messages
Do I need to purchase an updated FRM3 or is there something I missed in coding?
(vehicle date? or other?)
2020 X5M - Tanzanite II
2012 M3 - Alpine White
      03-05-2016, 06:23 AM   #11
blue dragon
If you want, I can send you a trace of my FRM3 that I am using for my headlights which has adaptive and higbeam working
      03-06-2016, 04:33 PM   #12
gixxerboy63
1047
2017 m4  [0.00]
Still having issue after updating the Footwell module to 3/16 and coding with Autologic.
Everything works for a moment after switching the car on... Headlights go through their normal up/down and side to side initialization function, then a few minutes later I get the Adataptive Headlight error message on the cluster display (and a bar in my Nav screen that blocks the clock). Once that happens, the headlights will remain stationary until I shut the car off again.
^he said clock block
That would be great!
...or maybe I all I need to do is change the order date to #0411?
      03-06-2016, 05:26 PM   #13
blue dragon
FSW_PSW - FRM3.txt
This is FRM3_E7X.C32.
If you run it through NCSDummy, you will see what all the options are.
Coded with FA date of #0411
