      03-07-2016, 01:50 PM   #1
E55 Bulldog
E55 Bulldog's Avatar
25
Drives: 2014 M6 GC
Oil Leak from Air Intake hose???
Good afternoon. I have a 2011 X5M and I have developed an oil leak from the air intake hose. It looks like the crank case oil vapors are collecting in my intake hose and dripping out where the hose meets the engine. I can't get the hose clamp tight enough to prevent it with out stripping it. Once it pools it will dip down the block, smell like hell from getting cooked, and eventually leave a drop or 2 on my garage floor?
It seems odd that I am getting that much old collection there. Anyone know why?
1997 HMC4 Hummer H1
2003 KSC2 Hummer H1
1969 Jaguar XKE
2014 M6 GC
      03-07-2016, 02:42 PM   #2
cbakking
Drives: E70-X5M
Could be related to this issue?
http://www.xbimmers.com/forums/showthread.php?t=952067
      11-27-2021, 03:09 PM   #3
iansanderson
Drives: 2013 X5M
Did you ever get to the bottom of this? I have this exact issue on my left intake boot and can't figure it out to save my life. I have tightened and moved everything around and still happening!
      11-27-2021, 03:21 PM   #4
Dawgz
2022 M4 Comp Xdrive
1015
Drives: 2022 M4 Comp Xdrive
You need to install oil catch cans
      11-27-2021, 09:38 PM   #5
XRatedM
XRatedM's Avatar
Drives: 11' X5M - 19' VW GTI
Mine is doing the exact same thing with catch cans, not sure if the ccv valve is bad or something else (oil separators and all ccv components replaced) thinking I'll just epoxy the darn connection
IG @E70_XRatedM | YT: E70M Garage
