      11-02-2017, 07:28 PM   #1
lipi128
Drives: 2011 Bmw X5 35D
Reduced Engine Power
Hey everyone,
I was leaving for work last week and my 2011 x5 35d randomly lost power and would not go up the hill and the dash lit up saying reduced engine power
Took it to the dealer and they said they thought it was a cracked egr cooler and it would cost $1500. The part costs $500 and I just replaced that myself and it is still saying the same thing and having reduced power.
Any thoughts on what else it could be?
Thanks!
      11-02-2017, 07:47 PM   #2
335dsleeper
Drives: 09' 335d 10'35D
Could be a lot of things. Bad MAF, pressure converter, boost leak etc.
If it’s giving you reduced power idrive message, you’ll have a trouble code stored. Read the codes and post.
      11-03-2017, 10:10 AM   #3
lipi128
The codes that are currently coming up are: P0101-p0069-p0401-p029
Thanks!!
      11-03-2017, 11:38 AM   #4
335dsleeper
Put them in google and get the description
      11-03-2017, 11:46 AM   #5
lipi128
P0101 - Mass air flow circuit range/performance problem
p0069 - Manifold absolute pressure sensor/barometric pressure correlation
p0401 - insufficient EGR flow
p0029 - Diagnostic powertrain trouble code
      11-03-2017, 01:04 PM   #6
335dsleeper
Unplug your MAF and see if driveability improves.
Could be vacuum lines or MAF. I don’t think it’s the MAP sensor.
      11-06-2017, 08:45 PM   #7
lipi128
I replaced the MAF and the car still runs with low engine power and struggles to get going. I read some places that it takes like 20 miles to reset? Could that be it or do I need to see what else it could be at this point? Thanks!
      11-06-2017, 09:39 PM   #8
racermp
racermp's Avatar
Drives: F30 330i
Do u not have a code scanner? Lots of free apps man....
      11-07-2017, 08:28 AM   #9
lipi128
I do have one and I put the codes above... but at this point I've changed out two things and it hasn't changed anything.
That's why I am looking for input
      11-07-2017, 09:44 AM   #10
JoeyBimX5din
Drives: 2011 BMX X5 Xdrive50i
Your not diagnosing the codes your just throwing parts. Apparently the dealer may have had the same mentality. Did they actually run through the diagnostics, or did this have codes, and they gave you a 'maybe this is bad'??
I googled the p0029 code, and it seems to be the exhaust valve control solenoid, maybe that is bad and is causing the valves to stay closed? This truck needs some actually troubleshooting, not parts throwing.
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD
1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about
1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter
      11-07-2017, 10:28 AM   #11
lipi128
Yea it was one of those "we think it's this.. but we'll have to test drive after to be sure". So I decided I'd save a grand but it's still doing the same. I guess I'll look into that as well! Thanks for your input!
      11-07-2017, 12:12 PM   #12
Maranello055
Drives: 2015 BMW X5M
Not saying this will solve your issues... But I've had that light and malfunction 3-5 times now...
1.) Wastegate needed replaced
2.) Coils and Plugs needed replaced because engine partition was cracked and water leaked in.
3.) 1 Fuel injector went bad (this week) - this is being replaced by the dealer today.
2015 X5M
      11-07-2017, 03:48 PM   #13
335dsleeper
Why did you replace the MAF?
You need to reset adaptations when you change the MAF. Not 100% necessary but, the correct way to do it.
      11-07-2017, 03:50 PM   #14
335dsleeper
Op has a diesel, not a petrol X5.
      11-08-2017, 11:10 AM   #15
JoeyBimX5din
I wish posters on this forum would refrain from doing this. This soft code message is such a general broad warning it can be almost anything on the engine.
