      11-02-2017, 04:09 PM   #1
esevx5
Drives: X5
Operating coolant temperature, what's normal?
edit
      11-03-2017, 08:43 AM   #2
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
On my 50i, 108 C is the highest I've observed, so that sounds about right .
      11-03-2017, 03:51 PM   #3
omgboost
Drives: 2012 X5 35i
On my 35i, I see 232F or around 110C.
      11-03-2017, 09:24 PM   #4
fsd350
fsd350's Avatar
Drives: 2010 BMW 335d
Yep that high a temp is normal for today's Bimmers. If you have not done so, a "Mike Miller" cooling system refresh may be in order.
      11-04-2017, 10:11 AM   #5
omgboost
Drives: 2012 X5 35i
Originally Posted by esevx5 View Post
I guess 108 I still a threshold for me because that's when my expansion tank cracked. Could also be a coincidence though as I don't think it has ever been replaced (129k miles)
Based on my research, the range is normal
Doesn't anyone know if the electric water pump varies its speed based on engine rpm or pedal pressure?
I noticed I drove around harder yersterday, yet the car ran much cooler (85C to 105C). I figured higher rpms would lead to a hotter running engine, but it was the opposite
Same here. I think the electronic water pump tries to be fuel efficient. If you don't run it hard, it won't cool the engine as much. When you run the engine hard, it goes into full time cooling mode which cools the engine more.
      11-05-2017, 09:39 AM   #6
Ryan5034
Drives: 2019 X5 50i
Don't forget when driving you also have a lot Air moving around instead of idling when you have none.
