      06-09-2017, 10:01 AM   #1
Movado750
Drives: 2012 X5 M Sport
Brake pad service reset at speedo cluster and dash screen.
I've been all over YouTube looking I can reset the one on the dash cluster but how in the hell do you do the one for in the Dash screen. The one above the radio...
Wife is driving me crazy complaining that she has to hit the menu button once to get ride of it.
      06-09-2017, 12:48 PM   #2
mitch808
Drives: 2012 X5 35i
Did you truly replace the brake pads, and brake sensors? Resetting the counter is one thing, but a worn brake sensor is another.
      06-09-2017, 03:45 PM   #3
Movado750
Yes I did both pads and sensors. This screen above the radio is what I can't get to reset.
      06-09-2017, 09:07 PM   #4
gan23
Drives: X5M '18 XM’23 X5 50e 24
Reset your odometer to 0 with the button on your dash, restart, hold the reset, you'll enter the submenu with all the CBS
1. Start car and reset trip odometer.
2. Turn off car; without your foot on the brake, press the start button. The car's electroincs will start.
3. As the car starts, press and hold the trip odometer reset until you get a yellow triangle with an exclamation point on the dash display, followed by entry into the service menu. Don't release until you are into the menu.
4. Pressing and releasing the trip odometer reset repeatedly walks you through all of the possible service intervals. The one for the front pads looked like an exclamation point up by the front quarter of the car. Any that need resetting will be red; the rest will be yellow.
5. When you get to the one you want, press and hold the trip odometer reset until the display says "Reset?". Then release, press, and hold until it resets.
If you do this too slowly you will be bounced out of the service menu. Just turn the car off and start again.
From http://www.bimmerfest.com/forums/sho...d.php?t=526713
      12-12-2017, 04:57 AM   #5
gghg
Drives: 06 M Coupe
brake pad light reset
I have the same issue, however when I try to reset the pad light for the front and rear brakes the KM goes to dashes for a second then the original km are shown (-430 for the front and 230 for the rear). Any suggestions on how to reset
