      12-18-2017, 10:19 AM   #1
Teh.brandon
Drives: 2011 X5M
Hey guys I'm looking for options for putting a bike rack on my X. I'm an avid road cyclist and occasionally need to load up the bike. Does anyone have the part number for an OEM roof bar setup or has anyone had luck with using an aftermarket option? I've looked around and haven't been able to definitively identify a part number for the OEM bars for a 2011 X5M. So I'm looking for some guidance.
Cheers
Update:Got the OEM part number if anyone is wondering for the X5M base support cross bars that works with the low profile rails on M-Sport and M: 82710405052
      12-18-2017, 01:05 PM   #2
ChiTownM
ChiTownM's Avatar
Drives: M and i BMWs
I ordered them directly with my dealer including my BMWCCA discount. They know which ones to order, no hassle. They fit perfectly and make sure to install the rubber as well or you will have a terrible hiss driving .... ask me how I know this lol.
      12-18-2017, 01:09 PM   #3
jiggz
Drives: E90 M3|F15 X5 50i
Are you referring to these? Obviously more is needed to mount a bike.
https://www.getbmwparts.com/partloca...catalogid=4462
      12-18-2017, 01:25 PM   #4
Teh.brandon
Drives: 2011 X5M
Yes that is what I'm wanting just didn't know if the regular x5 base support worked with the low profile rails on the x5m
      12-18-2017, 01:40 PM   #5
jiggz
I'm pretty sure this system works on all E70 X5's.
      12-18-2017, 02:13 PM   #6
Colodano
Drives: 2010 X5M
Looks basically identical to the Thule Aerobar setup I am using on mine.... Fits very well. I will try and dig up a pic on my phone...
      12-18-2017, 02:32 PM   #7
Teh.brandon
Drives: 2011 X5M
Nice I'd like to see it...really Thule and OEM are the only ways I'd go
      12-18-2017, 02:36 PM   #8
Colodano
Drives: 2010 X5M
Hopefully this works...
      12-18-2017, 02:50 PM   #9
Teh.brandon
Drives: 2011 X5M
[IMG]
View post on imgur.com
[/IMG]
Any idea on the part number for your setup minus the cargo attachment...great looking x5m btw
      12-18-2017, 03:00 PM   #10
Colodano
Drives: 2010 X5M
bar setup 7603B
Fit kit 4003
bike rack is a Rockymount SwitchHitter in white.
And thanks! Looks a tiny bit better now, I removed the chipped up black rocker stickers.
      12-19-2017, 10:43 AM   #11
Teh.brandon
Drives: 2011 X5M
Just called my local dealer parts department he said there are no OEM roof bar setups that will work with the "m" low profile roof rails...but he could have the rails swapped for the regular x high profile bars for about $700 hahaha...piss on that looks like I'm going the Thule route unless I can get this OEM enigma figured out which I was what I'm hoping to stay with
      12-19-2017, 11:46 AM   #12
philly42
Drives: X5M, Z3M
Are you going to go with the oem one 82710405052 or the thule? My X5M has the low profile roof rails.
      12-19-2017, 11:47 AM   #13
Teh.brandon
Drives: 2011 X5M
I'm going with the oem...Ive already ordered it so if you want me to be the test dummy just give me a few days and we'll see how it works out haha
      12-19-2017, 05:55 PM   #14
ChiTownM
ChiTownM's Avatar
Here is the part number, for X5M only: 82710405052
      12-29-2017, 12:59 PM   #15
Teh.brandon
Drives: 2011 X5M
Just an update installed the factory roof support system (cross bars) for the flush roof rails that are on the x5m and Msport models. It worked flawlessly and installed in 15mins. I'll post up some photos this evening
      11-27-2018, 08:39 AM   #16
flyoisin
United Arab Emirates
Drives: BMW E70 X5M
Is it a noisy set up?
Like any vibrations or rattles?
Can you notice it while you drive?
I'd like to do the same setup on my X5M! Thanks bro!
      11-27-2018, 09:52 AM   #17
Colodano
Drives: 2010 X5M
Only notice any wind noise when I have the roof panels tilted up, so I will close the roof above ~60 MPH. Other than that, I do not notice it, and no rattles or anything.
I do have the cargo box off most of the time, but I keep the rails and bike attachment on pretty much all the time.
      11-27-2018, 11:54 AM   #18
ncbimma
ncbimma's Avatar
100
Drives: 2012 BMW X5M
I went with the seasucker option.
And it stores perfectly in my subcargo compartment.
      11-28-2018, 10:42 AM   #19
philly42
Drives: X5M, Z3M
Yeah the seasucker is great and I use it mainly on the Z3M. So convenient! I ended up getting the roofrails for the X5M since a buddy gave me a BMW bike rack.
      07-22-2020, 11:04 AM   #20
drummr8
6MT FTMFW
Drives: 11 E90 335xi E91 6MT 12 X5 35i
what is that in your last picture? does the bike rack have a lever arm that can swing down or something?
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete
