03-05-2019, 12:58 PM | #1 |
Rep 76
Engine fire wall cover/protector ?
Mine is sagging off the attachment points,,not sure what it's called,,couldn't find it on ECS Tuning cuz I don't know what its called,,,lol. thx much
03-05-2019, 01:09 PM | #3 |
Rep 1,564
Do your engine a favor and throw it out (your engine cover and the rear parition). I am still on the fence if BMW left the engine compartment design up to the night cleaning crew and thus is was born of pure incompetence or if it was a carefully executed diabolical plan to accelerate the failure rates of those wonderful plastic and rubber parts through heat saturation, sening your back for more part$$$$
pdX5M111.50 |
03-05-2019, 01:09 PM | #4 | |
Rep 3,036
Drives: 2022 BMW X5
do uself a favor and buy a set of eBay for about $40 (all 3) rather than spending $200 at the dealer.
03-05-2019, 01:14 PM | #5 |
Rep 1,564
Here's some more food for thought....scan through this forum, look at how many threads on dried out vacuum lines, busted CCV tubes, leaking seals....BMW made the E70s engine compartment a TOMB...no wonder everything dries out and fails long before it should.....Let your engine breath and ditch that rear parition and the silly engine cover (keep the rain gutters though)
03-05-2019, 01:26 PM | #6 |
Rep 357
Redneck, I think all engine compartment suffers from heat soak. Its just Bmw uses parts that have poor poor quality. Doesn’t matter if you drive without a hood lol, when it breaks, it will break.
My hood latch on the passenger side just broke?!! Really? In my 20+ of driving and owning over dozens of vehicle from old to new, this is my first. What a nightmare! Had to use boroscope, metal rods and whatever super skills I have. |
03-05-2019, 01:29 PM | #7 | |
Rep 531
Drives: 2007 E70 4.8i, 2008 E90 335i
The lower center that also breaks... Part number: 51717169422 Plus the little side covers that also break.... Part numbers: 51757171791, 51757171792 (ebay ones work well but were the same price as OEM) I got them instead of OEM knowing that the OEM material doesn't last. I got the 3 piece ebay setup along with all of the other pieces incuding an OEM lower center. The 3 piece ebay replacement works pretty well. I did notice that it was hard to get the screw points aligned. I am not sure if they are slightly smaller than stock or if the stock setup really has them pull inward to fit (creating a stress point on them). I ended up trimming the notches on them them slightly to relieve the stress that they would have when pulling outward on the center piece. I actually wonder if they forgot to account for the material shrinkage after molding.... The ebay versions are either from the same factory as the originals or were made from a mold of the original. Mine even had BMW logos and part numbers on them... I am not sure if the material is the same as OEM (I hope not in this case). As mentioned I bought a new OEM lower center which is a pain to install and it also broke off in the lower outside connection points right out of the box. I ended up putting some JB weld to fix the cracks and strengthen it and so far so good.... The lower center is about the same price for the knockoff ebay version but any change from the stock material is likely a good thing so I would either just get the ebay instead of the OEM hoping for the best or buy from a supplier that does a lifetime warranty on it. I probably should have just returned mine but I wanted to put it back together and it was in a hidden spot where JB weld made it stronger than new. -Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. |
03-07-2019, 05:00 PM | #8 | |
Rep 357
Drives: E70 X5M
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
