10-30-2013, 09:03 AM | #1 |
Rep 27
2011 w/ M sport package. How can you tell if it is LCI?
Looking at the two pictures in the LCI - NON LCI thread those are both X5 without M sport. With M sport the fogs would be in the lower grill. Unless fogs in lower grill means LCI?
Help Thanks 1bbp |
10-30-2013, 10:25 AM | #4 |
Rep 708
10-30-2013, 10:32 AM | #5 |
Rep 27
10-30-2013, 01:32 PM | #6 | |
Rep 5,066
And then they changed it to White LEDs. Easiest way to tell the difference is the front bumper. The narrower front lower grills on each side are PRE- LCI and the bigger opening grills are LCI. You can also check by the rear bumpers if the bumpers are color painted match with the body of the car then it is LCI. If it is all black then it is Pre-LCI. |
10-30-2013, 02:28 PM | #8 |
Rep 708
10-30-2013, 02:50 PM | #9 |
Rep 5,066
10-30-2013, 03:46 PM | #10 |
Rep 3,995
If you have the VIN, you can lookup the production date here.
http://bmwvin.com
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
10-30-2013, 04:08 PM | #11 | |
Rep 27
10-30-2013, 04:12 PM | #12 |
Rep 3,995
I believe it was around Spring 2011.
10-30-2013, 04:17 PM | #14 |
Rep 3,995
That's to be expected. A normal 3 year lease for a 2010 build is up now, or soon. Used late-2011 models won't be widely available for another few months.
10-30-2013, 04:19 PM | #15 |
Rep 27
I guess I'll sit back and watch for a few months and see what happens. While I would like a new car now. I don't need it.
10-30-2013, 04:22 PM | #16 |
Rep 3,995
The LED coronas weren't a deal-breaker for me. I just added some LUX H8s, and the difference is close to negligible.
10-30-2013, 04:23 PM | #17 |
Rep 27
10-30-2013, 04:26 PM | #18 |
Rep 3,995
Yes, the LED coronas came standard on late-2011 and later models, before that they were an optional add-on.
LUX bulbs run $225 a set. http://luxangeleyes.com/products/lux-h8-v4
10-30-2013, 04:34 PM | #19 | |
Rep 27
10-30-2013, 09:39 PM | #20 | |
Rep 11,135
My suggestion? Just look until you find a 2011 with the OEM LEDs or a 2012,especially since you said you don't really need one now. |
10-31-2013, 08:23 AM | #21 | |
Rep 5,066
But to the OP, why in the world does a small cosmetic difference such as halo / angel eyes make or break a X5 for you? Its a small factor. |
10-31-2013, 08:38 AM | #22 | ||
Rep 3,995
LUX will replace the yellow amber light with a bright white light. Are they quite as bright as the OEM led coronas? Maybe not, but it gets you away from the dated yellow look which I think is what the OP is after. I had them on my M3 and in reality they are pretty good. For me, there were some deal breaker options (adaptive drive, multi-contour seats, premium sound) but the led-corona lights was not one of them.
