      10-09-2013, 11:50 AM   #1
vitiokas95
Drives: 2001 M5, 2008 E90 M3, 2010 X5d
E70 diesel won't start.
So this morning my 2010 X5 diesel did not started. It cranks, but engine just won't start. Checked all fuses, filled up DEF tanks, replaced battery etc but still nothing... Ran without problems before, has 100k miles on the clock.
Yesterday before going home after work, I noticed that it took more time for engine to start up, but since it started afterwards, it did not concerned me, but this morning it did not start at all.
Any ideas guys?
2018 M5
2009 E92 M3 race car
1988 E30 M3 (sold)
1990 E30 325is s50 swap race car (sold)
      10-10-2013, 09:53 AM   #2
vitiokas95
So last night I started it with starting fluid. Drove a bit and tried to start it again but still does not start without help of starting fluid. Took it to my mechanic this morning.
2018 M5
1988 E30 M3 (sold)
      10-10-2013, 07:30 PM   #3
Techjunkie666
Techjunkie666's Avatar
15
Drives: X5D SAV
What's the news on the X5 D? I just purchased one. Let me know what they tell u is wrong with it. Good luck
2014 F10 M5 (On Order)
'10 E92 M3, '09 E90 M3, '12 C63 AMG 507 Ed, '07 335i, '06 RS4
      10-11-2013, 08:55 AM   #4
vitiokas95
Looks like fuel pressure sensor. Should know this afternoon after it gets installed.
2018 M5
1988 E30 M3 (sold)
      10-15-2013, 08:56 AM   #5
vitiokas95
It was not a fuel pressure sensor. It was fuel pump located it fuel tank. Getting it replaced today. around $850 fix...
2018 M5
1988 E30 M3 (sold)
      10-23-2013, 12:27 PM   #6
vitiokas95
Guess what, been more than 2 weeks but my X5 still not fixed. Original mechanic replaced bunch of stuff which did not get it fixed. Took to another mechanic. He called me last night and told me he found that injector on cylinder 6 is bad. He will be replacing it today. Hopefully it helps...
2018 M5
1988 E30 M3 (sold)
      10-23-2013, 02:48 PM   #7
Techjunkie666
15
Drives: X5D SAV
That sucks. I'm guessing your X5 is out of warranty?
      10-23-2013, 08:09 PM   #8
vitiokas95
No warranty
2018 M5
1988 E30 M3 (sold)
      10-25-2013, 12:12 PM   #9
vitiokas95
Latest update... buying 6 new injectors, $2500 just for parts. Well, hopefully this fixes the problem, if not I will burn the damn thing!!!
2018 M5
1988 E30 M3 (sold)
      10-25-2013, 01:42 PM   #10
serge1
Drives: X5 35d
2011 BMW X5 35d  [0.00]
I thought everyone says that adding starting fluid to a diesel engine may damage glow plugs?
Do they even work? Reliably?
Is it possible you have bad fuel in the tank? Do you remember fueling up before the troubles?
From my perspective, it seems that your mechanic doens't really know what's wrong, and is just throwing parts at the problem. Kind of like dealerships do.
If I were you, I would spend a few hours to study the process how the BMW diesel engine starts, and trace a problem that way. I bet it will be cheaper for you this way!
      10-25-2013, 01:54 PM   #11
vitiokas95
It was definitely caused by bad diesel fuel. I already told my mechanic to drain bad fuel from tank. I fueled up in a gas station in which I never fueled up, usually I fuel up only at Shell or BP. Don't even remember why I had to use something else on that day.
2018 M5
1988 E30 M3 (sold)
      10-25-2013, 02:03 PM   #12
serge1
Drives: X5 35d
That's new in this story. Why are you spending your own money then? If that's what's happening.
Hire a lawyer, sue the gas station (they have insurance) and get your vehicle fixed properly - change the whole fueling system.
I usually try to avoid these mom-n-pap gas stations.
      10-25-2013, 04:19 PM   #13
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
Check relay in the back of the vehicle. These relays go bad often enough. Once it goes bad, car will not start. $10 - $20 part to be replaced. Easy DIY ...
      10-25-2013, 05:32 PM   #14
vitiokas95
There isn't one for Diesel X5
2018 M5
1988 E30 M3 (sold)
      10-25-2013, 06:27 PM   #15
serge1
Drives: X5 35d
Igor may be on to something.
http://www.realoem.com/bmw/showparts...=12&fg=15&hl=7
      10-26-2013, 11:31 AM   #16
vitiokas95
Picking up my X5 today. Got fixed last night. Mechanic drove it home and back to work with no issues. So it was bad fuel injectors.
