06-10-2013, 09:25 AM | #1 |
Rep 149
X5M KWV3
Anyone having any "popping" noises coming from their KW's during slow speed turns. Just had the KW's installed and my installer says this is normal on KW's. It's the coils unwinding on either the collar or top hat. Other than that the KW's are flawless but I just can't accept it. My installer said their may be a teflon sleeve you can install between the coil or top hat.
Anyone experience this or came up with a solution? |
06-10-2013, 11:33 AM | #3 |
Rep 596
I've had KW's on an M5, M3 and 335 - and all were perfect without any noise.
dk
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
06-10-2013, 02:03 PM | #4 |
Rep 149
Called KW again. Tom from KW said if you lower the hieght more than maximum allowable hieght you'll get popping noises from the coils while turning at slow speeds. I'll check the maximum allowable lowered height tonight and get back to you guys.
06-10-2013, 04:58 PM | #5 |
Rep 691
Please do. I've been on the fence about coils forever. Just hoping it will ride close to stock
2012 X5M Monte Carlo Blue/Black-SOLD
Velos Stage 2/Velos Catless downpipes/Dinan exhaust/Dinan Suspension 2018 M6 Gran Coupe Competition- Singapore Grey/Aragon Brown DME Stage 3 |
06-10-2013, 05:43 PM | #6 |
Rep 149
I was on the fence about the purchase as well for the longest time. I purchased a used set from a fellow forum member here. I have no regrets even with the popping noise, which i'm sure is fiaxble. The X5 feels so much more planted and controllable. Make the move you won't regret it.
09-20-2013, 01:27 AM | #7 |
Rep 1,909
Drives: 2023 M5C
Is anyone still experiencing a popping noise on their KW's? I noticed this for the first time earlier today pulling in to park on a flat surface. That sound made me cringe...
09-20-2013, 09:23 PM | #8 | |
Rep 567
That was back in 2011...since then there have been a few members complaining of this. It's called spring bind or coil bind...I posted a video on another thread which shows the issue clearly
| '10 Escalade ESV | '12 Audi S4 | '01 Audi S4 | '15 328d Xdrive M-Sportwagon |
09-20-2013, 10:57 PM | #9 |
Hooligan
55
Rep 680
that is unacceptable for a $4000+ set of springs.
2014 Porsche Cayenne Turbo S 2011 X5 5.0 Dinan - SOLD 2007 Imola Red Z4 M Coupe -SOLD 2004 Navy Blue BMW 325Ci |
10-22-2013, 09:10 AM | #10 |
Rep 1,909
Drives: 2023 M5C
So no fixes? Anyone?
10-22-2013, 10:42 AM | #12 |
Rep 1,909
Drives: 2023 M5C
It's not even a huge drop to begin with...
1.75" front / 1.5" rear |
10-22-2013, 11:31 AM | #13 |
Rep 708
Hmm. that is odd, and agreed that is not an extreme drop at all.
You could try re-clocking the springs and see if that helps at all. I presume everything is torqued down properly? My wife's M3 is on V3s and we had some noise going over bumps when we first had them installed. Turns out the large nut on the passenger shock tower was not properly torqued down. Once that was snugged-up they were perfect. |
10-22-2013, 06:10 PM | #14 |
Passes everything but the gas station
49
Rep 795
Hey OP not sure if you had this resolved. I don't have V3s on my X5M but I do have that popping sound as well. Makes me think it may be something else. Doubtful though.
I'm putting the Dinan springs on next week. Not quite as elaborate of a set up as the V3s, but I will be interested to see if I still get that noise |
10-22-2013, 07:07 PM | #15 | |
Hooligan
55
Rep 680
10-22-2013, 07:32 PM | #16 |
49
Rep 795
It's pretty conservative..about an inch all around. They fix the self leveling module as well I believe to compensate. Also replace all the bushings as well.
The labor time is stupid though. Dinan quotes 8 hours, which means the labor is more than the parts!!! I want to do coilovers on this car, but need this to be more to toned down than my M3. I get all my work done in Norwell. I used to go to Steve and Matt, who I still respect a great deal. However, the service aspect was awful and Norwell really takes great care and pride in their service. Plus they give a pretty good deal on the Dinan parts which I can't complain about. Send me a PM anytime and we can meet up. |
10-22-2013, 07:37 PM | #17 |
Hooligan
55
Rep 680
SouthShoreM3 has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
