05-02-2010, 12:04 PM | #1 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
Angel eye's bulb location
Need someone to help me find the location for the "angel'eye's" bulb ?
A picture or DIY instructions will help a lot Thanks in advance ! Bernie |
05-02-2010, 12:41 PM | #2 |
524
Rep 2,146
One more question, which bulb from this link (from RealOEM) is the one for the angel eye's?
http://www.realoem.com/bmw/showparts...60&hg=63&fg=05 Thanks |
05-02-2010, 02:18 PM | #3 | |
Ninja
390
Rep 4,014
did you check in your manual under "day running lamps"?
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
05-02-2010, 05:11 PM | #4 |
Xdrive
Rep 79
Motex,
Yes it is Bulb 4. When you look directly behind the light, you will see a 80 mm black cap. Unscrew & that gives you direct access to bulb 4. You need small hands to then twist the bayonet light socket. Bit fiddly but persistance pays off.
gjm
05-02-2010, 08:29 PM | #5 |
524
Rep 2,146
This is the second time my car burns that bulb, my car still has 3 more warranty months left, so tomorrow I will take it to the dealer once again.....
I was thinking in changing to super-white PIA bulbs, but since I have this reincident problem, I will pospone that project for later Thanks for your replies Bernie |
05-02-2010, 09:28 PM | #6 |
Ninja
390
Rep 4,014
are they H8 bulbs? If so, GP thunders are great AE replacement bulbs as well...price is good also..
05-02-2010, 09:39 PM | #7 |
Rep 61
Drives: 2009 BMW X6 xdrive35i
Garage List 2007 Toyota Hilux F ... [0.00]
2009 Toyota Landcru ... [0.00] 2008 VW Touareg R5 ... [0.00] 2009 Nissan Navara ... [0.00] 2008 Ford Ranger 3. ... [0.00] 2009 X6 xDrive35i [0.00] |
Angle eyes has two rings, is there just only one bulb?
05-02-2010, 11:02 PM | #8 |
524
Rep 2,146
05-02-2010, 11:26 PM | #9 |
Ninja
390
Rep 4,014
yes, the one H8 bulb's light (per side) is distributed between both rings, first the inner than the outter ring, casuing slight brightness difference in both...
05-03-2010, 01:39 PM | #10 |
Rep 1,882
05-03-2010, 04:12 PM | #11 |
524
Rep 2,146
Today they charged me for the burned bulb because they say "it is normal" so the life expectancy of those bulbs are below the 2 year mark......that is not right IMO. I was wrong about second time same bulb, first time was the right one, now it was the left one, but it feels like those bulbs are not lasting a normal life, and they are made by Osram in Germany, that means that probably in 18 months I will be buying bulbs again, what I did was to turn off the daylight driving lights feature just to give some extra life to those bulbs.....not logical for an expensive car like this.... Last edited by motex; 10-08-2010 at 06:31 PM.. |
