      09-05-2018, 09:46 AM   #1
Teeray
Teeray
Drives: 2016 X5 Xdrive 35i
New member, with an old question...
Just joined the Forum today, so I am sure this question has been seen before. Bought a 2016 X5, but only one key/remote was available. has anyone come up with a way to avoid buying an extra one for several hundred dollars? Surely in this technology era, someone has figured out a cheaper solution.
Thanks
Teeray
      09-05-2018, 10:22 AM   #2
Smonkbmw
Drives: 2013 x5 m57
2013 BMW x5 35d  [0.00]
I don't know the exact amounts but a plain key can be had for less than $150. But it is just to unlock your drivers door and any other keyed locks in the car. I believe it's flat so it would fit in a wallet.
I've heard you can re code a used key fob at the dealer, but the key in the remote would be different at that point, if it came with one.
This doesn't exactly answer your question but there's a option with the "valet key". Depends if you're after that or keyless entry etc.
      09-05-2018, 11:38 AM   #3
Teeray
Teeray
Not picky...
I don't care what kind of key it is...just want to be able to lock/unlock and start my car when I lose the only remote/key that I have now.
      09-05-2018, 01:01 PM   #4
do_0b
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
you can aways buy those china after market fobs on ebay for cheap but you still gotta pay someone to code it to your car. Still cheaper than buying a second fob from BMW + coding
      09-05-2018, 03:54 PM   #5
Teeray
Teeray
Thanks for advice
I appreciate those who took the time to give me some suggestions. My plan is to order one on Ebay (unless someone tells me that I will probably get ripped off) then look up the instructions for coding it myself.
Teeray
imposss61.00
      09-05-2018, 11:44 PM   #6
Smonkbmw
Drives: 2013 x5 m57
Lemme know how it goes, I'm in the same boat, 1 key life.
      09-06-2018, 08:42 PM   #7
Golde4u
Drives: X6M
I dont know of any ebay key fobs you can use. I purchased a used one and it will need to be reflashed by a locksmith with the right software. Good luck finding one. And then you still need the dealer to program it to your car.
