      12-21-2017, 07:59 PM   #1
E46toE90
Sparkling Graphite Metallic FTW
E46toE90's Avatar
151
Drives: lci m-sport e90 n55
What should I look for in a 2011 x5m
Looking into getting an x5m. Been looking for awhile haven't found anything worth buying. Found one at a bmw in jersey with horrible engine noise.
Besides the obvious what are things to look for?
I read in checking injectors to see if they were replaced also water pumps since there are two. What else?
When does serpantine belt have to be replaced?
Do these models suffer from oil leaks from valve cover and oil pan like other models?
      12-21-2017, 08:16 PM   #2
Crazy1323
Drives: X5M
Check if driveshaft recall has been done.
Check the brakes, if they need replacing you are looking at spending at least 2k in parts for all 4 corners, if using factory parts.
Also, I believe there were some infotainment upgrades on the 2012 model, just something to keep in mind.
      12-21-2017, 08:24 PM   #3
E46toE90
E46toE90's Avatar
151
Yep ecs tuning shows 1300 in just rotors and I don't seem to find anything like stop tech. Good one thanks
      12-22-2017, 12:20 AM   #4
Colodano
Drives: 2010 X5M
Also make sure the rear airbags and the pumps are good, all the electronics obviously, if it's in the range for Takata airbag recalls, fuel pump recall, vent hoses over the engine leaking oil, power tailgate issues, sunroof operation, alignment and any clunks, I had to replace a headlight ballast and the front swaybar links 2 months after buying my 2010, and still need to fix tailgate issues that I knew about when I bought it, oh and the coolant expansion tank sprung a leak as well, just fixed that today.
      12-22-2017, 09:06 AM   #5
godmans
Drives: 135i / 335i / X6M
There is a laundry list, but in cascading order, below are priority items:
1) Recall on secondary coolant pump + front driveshaft
2) Latest version (Index12) injectors and hopefully changed not too long ago as Index12 is not maintenance-free either
3) Hopefully new plugs and coil packs
4) Maintenance, i.e. is the owner doing regular enough oil changes, and whether the adjacent oils were regularly changed (tranny, x-case, front and rear diff, rear torque vectoring oils)
5) rear air bags
This is my 2cents, if you are somewhat a gear head and stay ahead of the maintenance needs of this truck, the E7X Ms have been relatively easy to manage!
      12-22-2017, 11:37 AM   #6
Texmexm5
Drives: 2011 X5M
Yupp i agree with the brakes. im looking at about $1600 in parts for front and rears.
      12-22-2017, 10:35 PM   #7
frankenm
frankenm's Avatar
96
Drives: 12' X5M, 99 M3
Dealership??
Besides the front rotors brakes are decently priced ... changed rear rotors/pads for less than 300...
Front rotors cost 600 last time I checked that’s with the drilled F85 rotors.
Rock auto has good decently priced parts most of which is same as OEM at half the price.
TheVazha685.50
      12-26-2017, 10:22 PM   #8
E46toE90
E46toE90's Avatar
151
Just the price in brakes make me not want this truck lol might just stick with My e90 for now
      12-27-2017, 10:03 AM   #9
godmans
If the brakes deter you.. honestly, you might want to look for more rational choices like a x5 35i that don't have the same M tax on parts.
      12-27-2017, 10:11 AM   #10
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
I love my 35i. Besides, it was just deemed to have the perfect amount of HP: https://jalopnik.com/i-have-determin...wer-1821531670
      12-27-2017, 10:12 AM   #11
E46toE90
E46toE90's Avatar
151
I wanted to swap the 335 for a x5m but doesn't seem logical. X5 35i won't be sporty enough for me. I'll wait a bit and get the x5m and keep the 335
      12-27-2017, 03:28 PM   #12
godmans
that makes sense, good luck
