      07-09-2016, 09:27 AM   #1
XX5Monster
Drives: 2017 BMW X5M
What Dyno have you used?
Has anyone on here used Dyno Dynamics to dyno there M? I've been doing a little research after I had my M on the dyno this week and found that they are being called the ego killer Aka "The Heartbreaker" cause it seems to always put out lower numbers than the Mustang Dyno and Dyno Jet. Also it looks like no matter what one you use there are things that the operator can due to cause lower or higher numbers based on different settings like correction factors. I'm wondering if any of you can shed any light on this subject or what experiences you've had using Dyno Dynamics or any others.
Velos Stage 2 + Tune , Fabspeed Supercup Exhaust, Active Autowerke downpipes
      07-10-2016, 12:04 PM   #2
Dr.Duct_Mossburg
Dr.Duct_Mossburg's Avatar
59
Drives: Space Gray · E70 X5M
No dyno is consistent unless its the same one. Dynes were never and probably never will be a way to measure two different vehicles on two different dynos. They're designed to give the tuner an understanding of the effects of his tune.
I've made 720ish on one dyno and 650 on another.
      07-11-2016, 09:45 AM   #3
XX5Monster
I hear ya and seems to be lots of variables with doing dyno testing.
