08-30-2023, 05:35 PM | #1 |
Rep 13
BMW X5 Diesel 2011 35D More Error Code Question
Anyone can help me with this?
I am having problem clearing this remaining code, anyone know which part do I need to replace? Please help me. |
08-30-2023, 06:45 PM | #2 |
Rep 13
Before I had more errors but able to clear majority
So far I have replaced EGR Cooler (Spring was broken) , All 6 glow plug and glow plug module. 2 Thermostats, Fuel Filters, Redid all the vacuum line. https://www.bimmerpost.com/forums/sh...php?p=30315113 |
08-31-2023, 08:31 AM | #3 |
Rep 13
Another type of code name in case if this is easier to pin point.
Do y’all think if replacing the Throttle Body and the Low Pressure EGR cooler would solve 3 out of 4 of the code? I can’t seems to figure out where is the low pressure EGR cooler is located, is it not located at a place that I can see it when opening the hood? |
09-06-2023, 05:24 PM | #4 |
Rep 13
Anyone able to help? Or should I just replace all including the EGR valve? And hope it will fixes it. Hahha.
- will be replacing throttle body as a start - might have to do a resistor 10 ohms fix on the passive tank. The EGR one is the one I have no clue what to do now. |
09-08-2023, 10:59 AM | #5 |
Rep 398
Check the return spring on the EGR cooler. It is in the front of the engine. You can trace it from the passenger side of the throttle body and runs downward along the front of the engine block.
Maybe it's time for an ABC treatment. |
