      04-09-2014, 08:29 AM   #1
mleun481
Drives: 2013 X5M
What floor jack for X5M?
Wanted to check what floor jack you guys are using. I only intend on using it to swap out summer / winter wheels, so I figured a 3 ton Arcan would suffice. Any thoughts?
      04-09-2014, 10:07 AM   #2
mitch808
Drives: 2012 X5 35i
Yes that is a good jack, it gets high enough to lift our SAV to remove wheels.
Safety first, always use jack stands...
      04-09-2014, 10:23 AM   #3
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
The Arcan XL 35R is a great jack. I've used one for many years on my X5 and X6.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      04-09-2014, 12:38 PM   #4
mleun481
Drives: 2013 X5M
Thanks! I was going to go with either the Arcan XL 35R or the other Arcan one - the blue 3 ton aluminum (ALJ3T) from Northern Tool.
      04-09-2014, 02:42 PM   #5
windsailor
windsailor's Avatar
Drives: 2013 X5M Black Saphire
I thought would do the same but, decided to leave it to the shop as the jack points, torque applied to nuts and other details may risk some damage. I'd always pop the hood up to avoid messing with the air suspension, it'll tell the computer the car is service mode.
      04-09-2014, 04:45 PM   #6
mleun481
Drives: 2013 X5M
To just swap out winter wheels, I'd do it myself. Just have to reset the TPMS. Never heard of having to pop the hood, though.
      04-09-2014, 05:05 PM   #7
denaliman
denaliman's Avatar
2013 X6M  [0.00]
easy swap. Just re-torque the lugs to spec. 101 ft/bs. I've got a jackpad adapter from Reverse Logic, no damage whatsoever.
      04-09-2014, 08:10 PM   #8
JVX6M
JVX6M's Avatar
Drives: 2023 BMW M3 Comp
Me also! Anyone else ever heard or used popping the hood trick?
      04-09-2014, 08:48 PM   #9
Draper
Draper's Avatar
3460
Drives: M4 Comp / Macan Turbo
+1
Burger also makes a jackpad adapter. I think I paid about $15 a year or two ago.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      04-09-2014, 11:33 PM   #10
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
+1 on the jack pad adapter, i got the ECS tuning one, works perfectly
whatever floor jack you have should work fine, i got the Michelin low profile once.
      04-12-2014, 04:07 PM   #11
mleun481
Drives: 2013 X5M
Is this the correct rear jack point?
      11-23-2014, 09:33 AM   #12
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
I bought a used factory jack from BMW Auto Recyclers in CA for $65 shipped, including the handle. Works like a charm and takes up no space.
      11-23-2014, 10:28 AM   #13
P1
P1's Avatar
11569
Drives: 2004 3/4 ton Duramax
Never heard of a jack pad adapter before. You learn something new every day.
