      04-08-2014, 09:00 PM   #1
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Horn won't stop!!
I posted in the X6M forum, but thought I would get a faster response here. So I get home today, park the car in the garage and 5 minutes later the horn starts to go off!! Won't stop. So I pulled the airbag off the steering wheel and it stopped. Any ideas what may cause this? Pinched wire or loose connection? Just strange. I haven't put back together for fear it will go off and wake everyone up.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      04-10-2014, 02:46 PM   #2
ncraig
Drives: R35
have you swapped steering wheel or paddle shifter? you can disconnet battery negative terminal and check those connection behind the airbag. I messed up once when I install new steering wheel: Upshift become my horn, made me me so upset, so I took everything apart and reconnect them, problem fixed.
      04-10-2014, 02:49 PM   #3
denaliman
denaliman's Avatar
2013 X6M  [0.00]
I think a loose wire. I popped the airbag out and made sure the connections were tight. I was messing around the day before installing the extended paddle shifters and may have inadvertently disturbed a wire. Fingers crossed it stays fixed.
      04-10-2014, 04:57 PM   #4
ncraig
Drives: R35
that must be the reason, even the route of wire inside steering wheel housing matters, have to follow original route
