      07-06-2015, 04:27 PM   #1
v0lume
Drives: 2011 BMW X5 35i
Opinion - BMS JB4 or RaceChip Ultimate - 35i E70
I spent a good couple of hours last night researching the Burger JB4 or RaceChip Ultimate and I just can't work out what to go for. I have a 2011 xDrive 35i and what a plug and play with not much fuss - I can find dyne results for the Burger JB4 but not much info on the RaceChip.
I have had three Burger Motorsport piggybacks so know that are good, just looking at other options before I commit.
Has anyone fitted a RaceChip to their 35i?
      07-06-2015, 07:10 PM   #2
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
Burger has a bigger community following. I'd go that route.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      07-06-2015, 08:14 PM   #3
socale39
Drives: 04 545i SMG
I think you answered your own question, Burger.
      07-06-2015, 08:41 PM   #4
Doc GTO
Wicked Fast +1
Doc GTO's Avatar
Drives: 13 X5 50i MSport/02 M3 Track
I like Burger. You can send Terry an email and he responds back usually same day with any answer to any questions.
Doc
2013 X5 50i M Sport/BMS Stage 1/Magnaflow/P3Cars gauge/H&R 1.2/Style 215s
2002 M3 Race car bimmerworld/Turner/Markert modified
      07-06-2015, 09:57 PM   #5
mitch808
Drives: 2012 X5 35i
Cobb accessport if it applies to your year
      07-07-2015, 07:53 AM   #6
omgboost
Drives: 2012 X5 35i
I have the BMS and am looking into the Cobb. I think the Cobb is much better than the BMS as you can run different settings on the Cobb. The Cobb only supports up to 2011 and maybe some early 2012s but I haven't tried yet.
      07-07-2015, 03:36 PM   #7
mitch808
Drives: 2012 X5 35i
You have to give your VIN to them to verify. It's not so much year, but more so build dates. Josh@ Cobb is your man to help you with that. I think he's in Austin TX.
I've had mine installed near a year at this point, running a stage 1+ map. Works great.
      07-08-2015, 08:47 AM   #8
TYMAH123
Drives: 2011 BMW X5 SAV
JB4 doesn't work on E70 X5 35i, I just ordered Stage 1 + intake for myself and anxiously waiting it's arrival next week Monday.
      10-02-2015, 12:09 PM   #9
GrantM.Smith
GrantM.Smith's Avatar
Drives: 13' X5 35i M-Sport
Stage 1
Any update on this? What are your opinions?
      10-02-2015, 03:54 PM   #10
omgboost
Drives: 2012 X5 35i
I have the JB3 in my car for almost a year now. I forget how a stock 35i drives. I like the tune a lot. Best value for the amount of power you get. The intake, you don't get any power increase, only better sound. Would hear the turbo spool. I didn't get the intake.
      10-23-2015, 08:42 AM   #11
TYMAH123
Sorry for the late reply but I think I already PMed you my feedback.
I like the tune, it does have a little more power, there are also a couple of downsides since this isn't a custom tune. The car feels a little unsure at certain times, the gas pedal feels like it has a flat spot at lower RPMs since now it does try to select a lower gear sometime prematurely I feel. Maybe I just haven't noticed it before even though I had this truck since new, around 5 years now.
The intake does let you hear the turbo, I like that sound so I'm no disappointed in it. I still have the tune as well so I'm keeping the extra grunt and just have to live with the small shortcomings.
Initially I had a couple of codes thrown (overboosting and 4wd warning), after clearing the codes they haven't come back so I don't know if it was a fluke or what. The overboosting could've came from a gap in the intake tube, I re-tied my connectors and cleared the codes after that. I think 4wd was thrown because of the weak battery a couple of months prior.
Overall I like the tune, and I'm keeping it for the time being, hope it helps!
      11-13-2015, 01:46 PM   #12
Modedx5
Drives: 2012 X5 35i
I have the Cobb APV2. I also have the VRSF downpipe, charge pipe, and intercooler and the BMS Intake. There is a nice increase in power over stock. Mine also throws a code at high speeds 130+. Other than that I drive it everyday and it's very reliable.
      11-13-2015, 02:22 PM   #13
mitch808
Drives: 2012 X5 35i
Cobb really is the best option if you want to futureproof yourself. You can program, unprogram, clear codes, and get a custom tune too. All in a nice handheld device
      11-13-2015, 03:19 PM   #14
GrantM.Smith
I was under the impression that the accessport was not avaialable for late production E70s. Mine is a 13'.
      11-13-2015, 03:29 PM   #15
mitch808
Drives: 2012 X5 35i
Very possible, which is why I said earlier to check with Cobb and your VIN.
      11-13-2015, 03:31 PM   #16
GrantM.Smith
I see, thanks for the info. Twice.
      12-04-2015, 11:40 PM   #17
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Terry himself told me the JB4 won't work on E** vehicles. Can the JB3 do data logging? I need something that'll show me accurate boost and whatnot for tuning for meth.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      12-05-2015, 12:24 PM   #18
mitch808
Drives: 2012 X5 35i
Sounds like an overboost condition or no removal of the speed limiter. Only a ProTune can fix those issues. Which you could extract even more power than the base maps.
      12-08-2015, 01:20 AM   #19
m5james
m5james's Avatar
Bump for omgboost...
      12-08-2015, 07:48 AM   #20
omgboost
Drives: 2012 X5 35i
Sorry, didn't see the post when you replied.
From what I read, the BMS Data cable works for the JB3. You plug it in and install the JB software which will get you the logs and you can even change boost values if you like. http://www.burgertuning.com/USB_Cable_Extension.html
Also, yes, JB4 doesn't work on the E70 chassis. The JB tune that works on the E70 is the N55 Stage 1 or what everyone refers to as JB3
      12-08-2015, 05:55 PM   #21
m5james
m5james's Avatar
I'll have to write try to see if he makes the JB3 anymore or if it's strictly an I6 engine kinda thing. Thanks.
      12-08-2015, 06:24 PM   #22
omgboost
Drives: 2012 X5 35i
They have a tune for the Ms. http://www.burgertuning.com/M3_M4_M5...nce_Tuner.html The link to the data cable is on there as well.
