03-19-2024, 04:38 PM | #1 |
Rep 76
Bilstein B16 Damptronic Max Drop
Recently picked up a set of Bilstein B16 Damptronics for my F82, love the set but I want a more aggressive fit. Looking to match H&R super sports (1.6in drop upfront, 1in drop in the rear)
Has anyone tried this on the b16’s, if so, how has it affected the coilovers? Don’t want to compromise performance for a slightly more aggressive stance. |
03-20-2024, 09:41 AM | #2 |
Rep 5,551
Front range is 30-40 mm and rear range is 5-25 mm. Have you set the ride height per Bilstein’s instructions? Did you measure your ride heights before and after installing the B16? The before and after values are what you need to make sure you’re in the 30-40 mm range.. Based on a max of 40 mm, that should be close to front ride height you’re looking for - 40 mm = 1.57”. Bilsteins are not designed to be slammed.
03-27-2024, 10:25 PM | #3 | |
Rep 5,551
TSL3.50 |
03-27-2024, 10:28 PM | #4 | |
Rep 76
03-27-2024, 11:09 PM | #5 | |
Rep 5,551
Cowsgomoo128427.00 TSL3.50 |
03-30-2024, 10:47 PM | #6 | |
Rep 76
